Synchronizer - Mustang Evolution
Old 01-25-2015, 09:59 PM   #1
joe_117's Avatar
Synchronizer
How much does it cost to replace one of these??
joe_117 is offline   Reply With Quote
Old 01-25-2015, 10:25 PM   #2
alecas447's Avatar
I'm wondering the same I think mine are going bad. From what I've heard it can be a pretty expensive repair mainly labor. High hundreds from what I've heard. Hopefully someone with more know leg can chime in
alecas447 is offline   Reply With Quote
Old 01-26-2015, 03:22 AM   #3
fenixignition's Avatar
Do we have a synchronizer on the gt? Do you have a picture?
Sent from my GT-P3113 using Mustang Evolution mobile app
2002 GT 5sp. 16x,xxx miles
Old 01-26-2015, 07:08 AM   #4
joe_117's Avatar
Id have to show you after I get out of school. Plus I'm not sure how I'm going to show it. I've just been shifting and it's been annoying because it grinds, making it tough to put it in gear unless it's something else(pressure plate,etc..)
Old 01-26-2015, 08:56 AM   #5
oh. transmission synchros. sorry. i derped. i was thinkin camswhaft synchronizer for cars without coil on plugs
Old 01-26-2015, 09:02 AM   #6
check your clutch cable, quadrant, etc. could be that its still rubbing the flywheel, and turning a bit. Im not sure what bad synchros feel like, but sometimes grinding is caused by slack in the cable.
what i want to know, is what happens when the synchros are absolutely shot? do you just cram it into gear? drive it like a semi? go nuts power shifting all day?
but if you gotta fix one synchro, id just invest in a transmission rebuild. or swap it for a rebuilt transmission. if a synchro is out, then who knows what gears or bearings will go.
what was that transmission place called? i think aamco. they specialize in transmissions. may cost a pretty penny but i would call them first.
Old 01-26-2015, 09:11 AM   #7
Panther140's Avatar
Make sure that your clutch is adjusted properly first of all. Just take the dust cover off on the bottom of the tranny to expose the clutch fork. If the cable is too loose you might not get the disengagement that you need to smoothly shift gears. I personally wish there was a way to convert these transmissions to a dog-box. Dog boxes are ****in sick
Panther140 is offline   Reply With Quote
Old 01-26-2015, 09:14 AM   #8
Panther140's Avatar
As in, put a dog ring on instead of a syncro ring and have the gear machined to accept the dog ring. Maybe you could have some gears synchro and some gears dog box lol.
Old 01-26-2015, 11:03 AM   #9
alecas447's Avatar
I get the same symptoms hard to put in first and third
Old 01-26-2015, 11:09 AM   #10
hmm.. what about forks? i know on some transmissions those sucked.
Old 01-26-2015, 01:19 PM   #11
joe_117's Avatar
I have tr3650 tranny
Old 01-26-2015, 03:31 PM   #12
Speed_Mister's Avatar
Region: Arkansas
it's hard to diagnose synchros unless you tried refilling the tranny fluid and adjusting clutch. Even at that point it could be anything from a bent shift fork, worn out shift fork pad, broken gear, and then maybe a worn out synchro. Really you need somebody to drive your car to tell if it is synchros. And to see what's really is going on it needs to be taken apart.
I had bad synchros once before a couple times and continued racing, eventually the pin that held the shift forks in place feel out and I had no 3rd and 4th gear. I got a link for you where you can buy synchros. And you may want to do what I did take the tranny out yourself, and give it to the person who will rebuild it. I got a couple of guys in my contacts that will do a tr-3650 rebuild for 350$ idk if one of them are any good though. I know one is because he showed me how 3 times.
2004 Mustang GT 5 Speed Full Bolt On 360rwhp 440rwtq
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 01-26-2015, 05:35 PM   #13
joe_117's Avatar
Well I'm not sure if it is the synchronizer. Dustin told me I need to fix it. But you could be right on that. And rebuild my tranny for 350$?
Old 01-26-2015, 09:05 PM   #14
alecas447's Avatar
Is there any DIY for refilling the tranny?
Old 01-26-2015, 09:10 PM   #15
natestang07's Avatar
Just go through the shifter and fill it from in the car
Old 01-26-2015, 09:15 PM   #16
Region: Arkansas
Try draining it and filling the tranny up with synchro mesh first if it doesn't fix the problem. Just don't shift hard, shift slowly that's what caused my gears to go out before.
Full Bolt Ons
370rwhp 470rwtq
Old 02-03-2015, 10:58 AM   #17
Rcon127's Avatar
Not sure where you guys have landed on this but I just bought my 02 that we think the 3rd gear Synchro is going out on it. I called like 10 shops in my area to get quotes. So far from what I've read above everyone is on the right track. grinding can be a lot of things. It could just be some slack in your clutch cable and cost you nothing but some of your own time to tighten it up. It also could be any number of things involving the clutch, fly wheel, and tranny all together. I got estimates ranging from $800 if its just the synchro all the way up to $2300 if its worst case scenario.
IMO if it starts to get anywhere near $1500, I'm going to be looking for a nice new transmission.
Bottom line is that until you break open the tranny and find out exactly what it is, its hard to say just how much it will cost.
Rcon127 is offline   Reply With Quote
Old 02-03-2015, 11:18 AM   #18
alecas447's Avatar
yea^ personally I think mine is the clutch cable. If mine is the synchronizer I wouldn't mind as I've heard multiple times the car can run fine with bad synchros
Old 02-03-2015, 11:23 AM   #19
Rcon127's Avatar
One thing to keep in mind is that with bad synchro, you will likely damage other parts of your transmission over time. It may only cost you a few hundred now but if you wait, you may end up having to do a complete tranny rebuild. Yes you can run with bad synchros as long as you can perfect double clutching and not power shifting but thats only a temporary fix to a permanent problem.
Old 02-04-2015, 05:25 AM   #20
Transmission Synchronizer Qwik Four Six 1979-1995 Mustang GT 19 05-15-2011 08:35 AM
07:14 AM
