Alternator wiring - Mustang Evolution
Old 01-26-2015, 08:48 AM   #1
Panther140's Avatar
Alternator wiring
I don't want to mess things up with my car's electric, so I am going to double check with you guys where my alternator wire connects to. Its the red one that comes from the top of the alternator, do I connect that to my battery junction box on the Hot terminal for it? I lightly touched it to that and it sparked pretty hard when the car was running. I figure that would be because the alternator might be running a lot of amps and the amount of surface area at the contact point was too small to handle it.
Panther140 is offline   Reply With Quote
Old 01-26-2015, 11:29 AM   #2
Disconnect the battery before working on the electrical system!
Yes. It connects to the junction box and, on my car, there is a fusible link and it splits off to two separate wires that connect to the junction box.
Old 01-26-2015, 12:09 PM   #3
Panther140's Avatar
Yeah it is a good idea to disconnect the battery, but my thought was "If I hook this up to the wrong thing, secure it, reconnect the batter, and start it, I wont know anything is wrong until everything is fried"
Id almost rather risk an electrical burn! That is MUCH easier to fix than frying an ECU and wiring ****.
Old 01-26-2015, 12:21 PM   #4
Lol.
You will live after receiving any shock that an automobile electrical system can give you (Except maybe a hybrid)...
Some of the electrical components may not be so lucky!
It is good practice to always disconnect the battery before disconnecting ANY of the electronics.
Old 01-26-2015, 12:24 PM   #5
Panther140's Avatar
Lol.
Yeah 12 volt DC is pretty safe. However, I have seen people welding with jumper cables, 2 batteries wired in parallel, and a 60xx welding rod. It actually works pretty well on heavy metals
Alternator wiring hell Tyoung68 Mustang Audio & Video 0 11-11-2012 01:34 PM
2000 Mustang V6 Wiring Door panel wiring problem wyatt-00' Pre-2005 V6 Mustang 3 11-30-2009 12:43 AM
fox body alternator to classic mustang wiring harness ericgreen29 Classic Mustangs 0 07-18-2009 07:35 PM
Wiring a 1-wire alternator after swapping out a generator???? donaldva Classic Mustangs 4 04-22-2008 04:37 AM
96 GT alternator Rellik Pre-2005 V6 Mustang 8 11-19-2003 11:12 AM
10:54 PM
