Cut springs? - Mustang Evolution
Old 01-26-2015, 09:16 AM   #1
LeoGMR4558's Avatar
Cut springs?
Anyone running on cut springs on their oem ones? How's the ride and handling? Y'all recommend it?
LeoGMR4558 is offline   Reply With Quote
Old 01-26-2015, 09:21 AM   #2
Panther140's Avatar
Ive cut springs before and it was alright. It obviously made the ride rougher, but that's because cutting springs reduces suspension travel as well as makes your spring stiffer. Think about it, there are fewer coils to flex. So if each 360 degree coil accounts for 1" of travel at 500 lbs, then 10 coils will travel 10" when a 500lb load is applied.
Each spring takes the full weight eventually when you hit a bump, all springs do is spread out the impulse of the contact. More coils means more reduction in the amount of time it takes for the car to be affected by the load.
Panther140 is offline   Reply With Quote
Old 01-26-2015, 09:46 AM   #3
Mile high JDF's Avatar
I'm running cut Cobra springs with my IRS. I'm dropped 2.5" front and 2" rear so the ride is harsh either eay. I don't have issues with noise or bottoming out though
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 01-26-2015, 03:45 PM   #4
Steve96's Avatar
If you run a quality heavy duty shock strut set up you will be OK as long as you don't cut too much off.
1996 GT
Old 01-26-2015, 05:40 PM   #5
DetroitMuscle99's Avatar
I am. Changing it out asap I hate it plus I get tire rub if I turn the wheel all the way but run 19's as street gear which I'm changing also. Rides to ruff for me plus probly not the best plan for what I'm trying to do but was no doing of mine, previous owner cut them.
DetroitMuscle99 is offline   Reply With Quote
Old 01-27-2015, 12:46 AM   #6
LeoGMR4558's Avatar
So just a rough ride huh?
Old 01-27-2015, 03:56 AM   #7
I mean the stance is nice looking, may handle slightly better in turns because of less roll but just don't like it imo.
Old 01-27-2015, 07:03 PM   #8
Billgluckman's Avatar
I've never had cut springs but I did run eibach pro kit springs for a while. The ride was horrible and my wheels rubbed the sway bar on sharp turns. I'm totally against lowering if the car is a dd or anything close to a dd, but that's just my opinion.
I will say lowered looks a million times better, just no fun to drive on the roads around here.
Billgluckman is offline   Reply With Quote
Old 01-28-2015, 08:13 PM   #9
Honestly, I cut one coil off each spring, and Iiked the way it looked, but the ride was horrible. It was so stiff that the car just wasn't fun to drive anymore and seemed more like a chore to drive. I ended up buying h&r race springs and the ride height stayed the same as the cut springs but the car felt so much better overall. My suggestion is don't cut the stock springs. Save up and buy some good springs.
03redzo6 is offline   Reply With Quote
Old 01-29-2015, 03:42 PM   #10
Slater2111's Avatar
Anyone know how good or bad the Eibach pro system plus is for our cars. I like how it's a complete strut, spring, and sway bar kit. I am looking at getting those and getting J&m upper and lower control arms, MM castor camber plates and the steeda bump steer kit. Anyone have thoughts on this??? Anyone recommend something else???
Sent from the mothership.
Slater2111 is offline   Reply With Quote
Old 01-29-2015, 07:56 PM   #11
Panther140's Avatar
yeah cut springs ride rough as **** on cars that come from the factory with their suspension set up in an intentional way. The engineers figured out the suspension to best suit daily driving with occasional spirited driving on these cars. So cutting the springs kinda forks up the mojo.
However, I had a grand marquis once.. Cutting the springs on that damn thing was necessary if you wanted to maintain control of the car. The stock springs had about 3 whole feet of travel and no rebound dampening, so riding in the thing felt like you were driving on a trampoline haha. Miss that car tho! Up until I come to a corner, then I don't miss it. Literally drove worse than a pontoon boat in the corners
Old 01-29-2015, 08:04 PM   #12
Cutting springs is the worst thing to ever do.
Do it right and get aftermarket springs.
Old 01-29-2015, 08:21 PM   #13
2 Stangz's Avatar
Region: Nevada
Yeah I never understood how people could just cut their springs and just call it a day right there. Much more to it...
Old 01-29-2015, 09:07 PM   #14
Slater2111's Avatar
So what's everyone's suggestion?
Old 01-29-2015, 10:06 PM   #15
Don't cut the stock springs and buy some aftermarket springs lol
Old 01-29-2015, 10:11 PM   #16
Slater2111's Avatar
Right. I wouldn't do that anyhow. I posted a few places up on things I have in a build list and asked if they were suitable and how well they worked. But it seems that it was overlooked.
Old 01-29-2015, 10:41 PM   #17
I have a set of stock Bullitt springs I'm willing to give up. They lower about 1" without isolators and they have a pretty stiff spring rate so they will handle well.
Old 01-29-2015, 10:51 PM   #18
Slater2111's Avatar
I appreciate it. But I was looking to get the whole Eibach pro system plus kit, J&M upper and lower control arms, MM castor camber plates, steeda bump steer kit, and steeda chromoly strut tower brace? Is this pretty complete or is there anything wrong with the components?
Old 01-29-2015, 11:00 PM   #19
Steve96's Avatar
Nothing wrong with that list of parts at all. That will most definitely do what you want it to. Go with it.
1996 GT
Old 01-29-2015, 11:12 PM   #20
What's your goal for the car?
Old 01-29-2015, 11:56 PM   #21
Panther140's Avatar
Go fast!!
Old 01-30-2015, 12:04 AM   #22
Originally Posted by Panther140 View Post
Go fast!!
There are a lot of different ways to go fast.
Old 01-30-2015, 10:31 AM   #23
Slater2111's Avatar
My goal for the car will eventually be strip with a little street. But for now it's a daily. I will have plenty of money within the next 6 months to do all the suspension work at once and am trying to get a whole list together. In the next month or so I'm doing gears and bearings in the whole car. Along with deep sump tranny pan,GT500 diff cover, carbon lok rebuild and new spider gears, and O/R X or H pipe.
Cut springs to H&R Springs Slow4V 1996-2004 Mustang GT 4 10-16-2014 02:03 PM
cut coil springs fordracing63857 1979-1995 Mustang GT 4 10-30-2012 09:53 PM
Cut springs Surffer227 Pre-2005 V6 Mustang 47 03-01-2012 01:43 AM
where to cut the springs? I_luv_HP&trq Pre-2005 V6 Mustang 6 11-15-2005 10:16 AM
Will this cut springs? Stangthang Pre-2005 V6 Mustang 7 02-28-2005 07:01 PM
10:06 AM
