Unsmooth feeling clutch pedal - Mustang Evolution
Old 01-26-2015, 11:11 AM   #1
GHO5T5NIPER's Avatar
Hey guys my 02 GT's clutch has been feeling kind of grainy or unsmooth. It's honestly not too bad but it bothers me. My dad drove it and couldn't even notice it. Stock clutch and linkage. When engine is off it's smooth but when I drive I can feel the "grainy" feeling. At idle when I put the clutch in it is almost perfectly smooth but still not smooth as butter. Definitely more noticeable when being driven/ higher rpms. Thanks!
GHO5T5NIPER is offline   Reply With Quote
Old 01-26-2015, 11:13 AM   #2
90k miles
Old 01-26-2015, 11:24 AM   #3
fenixignition's Avatar
wait, what? grainy when? pushing the pedal down? or while its slipping and engaging? you might have to elaborate a lot more.
2002 GT 5sp. 16x,xxx miles
Old 01-26-2015, 11:25 AM   #4
I can feel it when it's both being pushed in and let out. Car still drives perfectly fine
Old 01-26-2015, 11:29 AM   #5
did it just start happening or was it like that when you got it? i have an 02 as well, and theres not much about it that i would use the word "smooth" to describe it.
right now mine makes a little squeak over by the clutch fork when i engage or disengage the clutch. otherwise, the only grainy feeling ive ever got was just the vibrations all together from this big engine/transmission setup of the car.
Old 01-26-2015, 11:31 AM   #6
It didn't use to do it. I've had the car for over 2 years and I just noticed it last summer
Old 01-26-2015, 12:22 PM   #7
Panther140's Avatar
Clutch cable could be getting a little old and wearing/scuffing the sheath that it moves through. I know in motocross bikes, a 2 year old cable was noticably less smooth than a brand new clutch cable. Otherwise the actual linkage in the clutch pedal assembly might benefit from lube.
Panther140 is offline   Reply With Quote
Old 01-26-2015, 12:33 PM   #8
See that's what I was thinking but if it were just the cable then I would feel the unsmoothness when the car is off also right? It's perfectly smooth ol when the car is off, but when it's running is when I feel the unsmoothness.
Old 01-26-2015, 08:54 PM   #9
Bump
Old 01-27-2015, 10:11 AM   #10
Cable could have been replaced at some point too. If they cheaped out and used a junk cable it could be frayed. Would be a good time to do the whole max motorsports kit.
Old 01-27-2015, 03:49 PM   #11
But what I don't get is it feels perfectly smooth when the car is off. Wouldn't it be unsmooth when the car is off too if the cable is bad?
Clutch Pedal Height Adjustment and Clutch Freeplay Mod ab_mach1 1996-2004 Mustang GT 126 10-20-2017 03:21 AM
clutch clutch... clutch Butch SVT Mustang 4 06-29-2012 03:53 PM
Clutch catching feeling jjsg09 1996-2004 Mustang GT 4 05-10-2011 10:27 AM
Clutch Feeling Sponge-like 19Delta Pre-2005 V6 Mustang 10 04-14-2009 01:07 PM
clutch pedal sags? tedness Pre-2005 V6 Mustang 4 03-19-2005 11:10 AM
11:11 AM
