Which mod first? - Mustang Evolution
Old 01-28-2015, 04:26 PM   #1
keeney35's Avatar
Which mod first?
04' GT 5 speed.. Right now I have factory manifolds, but the rest of the exhaust is all brand new 2.5" all the way back... Bassani H pipe, super 10's and no cats.. I've got a steeda cold air, steeda short throw, and every suspension mod you can imagine...
I'm looking at 2 things for tax money.. 1 I am most definitely changing gears right now I've got the factory limited slip 3.27's... this is my daily driver so in gonna swap in 3.73 instead of 4.10's.. Has anyone swapped in 3.73's and could you tell a big difference?
Next I'm deciding between getting longtubes to complete the exhaust or throttle body and intake...
What do y'all think?Click image for larger version
Name:	ImageUploadedByMustang Evolution1422483954.089685.jpg
keeney35 is offline   Reply With Quote
Old 01-28-2015, 04:26 PM   #2
keeney35's Avatar
Also I've got underdrive pulleys already too.
Old 01-28-2015, 04:30 PM   #3
2014Vert's Avatar
The 4.6's are choked up on both sides of the engine so both will help out. I'd probably do headers first just to finish up the exhaust, but the throttle body/intake will definitely help it breath better. I'd look into upgrading the intake plenum as well. They are super restrictive from the factory.
2014Vert is offline   Reply With Quote
Old 01-28-2015, 04:34 PM   #4
keeney35's Avatar
Sorry that's what I meant, throttle body and plenum, any brands to stay away from
Old 01-28-2015, 04:45 PM   #5
2014Vert's Avatar
I've always been a huge fan of TrickFlow. C&L is a good one too. They were good when the cars were new, not sure about any of the new ones.
Old 01-28-2015, 04:47 PM   #6
keeney35's Avatar
I was looking at bbk and accufab maybe SR
Old 01-28-2015, 04:51 PM   #7
2014Vert's Avatar
Accufab is pretty good if I remember correctly. I don't think the BBK one flows as well (I like BBK exhaust, but the intake side isn't as good). I don't know anything about SR except that it's American Muscles brand.
Old 01-28-2015, 05:26 PM   #8
keeney35's Avatar
I've had good experiences with American muscle, but I know accufab is pretty expensive I'll take a look at trick flow, install pretty easy for the plenum and throttle body
Old 01-28-2015, 07:13 PM   #9
Steve96's Avatar
Get the trickflow. It's a happy medium and high quality. Flows almost as well as the accufab.
1996 GT
Old 01-28-2015, 07:56 PM   #10
Billgluckman's Avatar
The gear swap will be the biggest improvement.
Billgluckman is offline   Reply With Quote
Old 01-28-2015, 09:21 PM   #11
Jay180's Avatar
Nice stang 👍
Jay180 is offline   Reply With Quote
Old 01-30-2015, 12:21 AM   #12
keeney35's Avatar
I'm looking at throttle body and plenums, is 78mm really too big for a n/a car? I will have long tubes, cold air, cam, new tune, and already have underdrive pulleys and new gears next week.. I've heard 78mm is too big and you don't gain anything... Stock I know is 56mm so I have 3 options 70,75, or 78mm... What to do what to do
Old 01-30-2015, 08:24 AM   #13
Stock tb is not 56mm, whoever told you that... I would not listen to them for anymore advice.
Mods for a 2V should go like:
-Gears
-Shifter
-Mid pipe/catback
-Plenum/75mm TB
-Suspension suspension suspension
-Wheels/tires
-Tune
Cams are a very expensive proposition and you might as well just get a supercharger when all is said and done for the $1000-$1500 it is going to cost you to get the cams done depending on if you DIY or have a shop do it.
Longtubes... the stock manifolds are not restrictive. Longtubes will pick up power, but if you combine what longtubes and a set of cams will cost, you can do a S trim supercharger which will take you up to the power limit of the stock motor and that is with the stock manifolds and cams.
In all honesty, to be legit fast, a 2V needs a full motor build, head work and boost.
First Mustang...First Ford...First Car This Awesome! Debster New Member Introductions & Greetings 13 04-28-2013 01:30 PM
First Post, First Car, First Mustangg EdgeLivin New Member Introductions & Greetings 14 04-03-2012 01:49 PM
12:51 PM
