New clutch break in - Mustang Evolution
Old 01-29-2015, 06:49 AM   #1
robin_gt's Avatar
New clutch break in
hi folks,
just got my exedy stage 2 clutch along with a ford racing pilot and throw out bearing installed. Now i've driven the car for about 100 miles always shifting no higher than 2k rpms. Every once in a while i get clutch chatter when i put the clutch in. Is that due to the fact that the clutch has not been broken in yet? Whats the proper breaking in procedure? Thanks.
robin_gt is offline   Reply With Quote
Old 01-29-2015, 07:01 AM   #2
Mine never chattered, did you put in a new flywheel too? If not, the old flywheel could have hotspots from the old clutch and it can **** up the mating surface. You should always do a resurface or a new flywheel when you do the clutch.
To answer your question, proper break in is to go easy on it with a lot of start/stop engagements over a 500 mile period. Then go nuts.
Old 01-29-2015, 07:03 AM   #3
robin_gt's Avatar
ยด
yea i also got the flywheel resurfaced hope the chatter goes away with time
thanks for the reply
Old 01-29-2015, 07:05 AM   #4
Just keep doing a lot of stop/starts and it should go away. But like I said my Exedy Mach 400 with a new flywheel never chattered once.
Old 01-29-2015, 07:07 AM   #5
robin_gt's Avatar
just watched a youtube video on clutch chatter lol.
mine is not like that just sometimes when in put the clutch in to shift from 1-2 gear it will make kinda a clank/chatter noise but it goes away once it is in gear.
Old 01-29-2015, 07:11 AM   #6
That chatter is the pressure plate skipping on the flywheel before there is enough pressure to catch. Once it gets a better mating surface going with the flywheel it should stop. As long as the place that did the resurface did a good job and its nice and flat you should have no problems there.
Old 01-29-2015, 07:16 AM   #7
robin_gt's Avatar
Ok thanks for the info
also the other thing is my clutch catches a bit high what can i do to adjust it?
Old 01-29-2015, 08:13 AM   #8
See if you have a stock quadrant or a double hook or whatever in there from a previous owner. If the cable is stock/OEM leave it, if its aftermarket swap it out with an OEM one.
Adjusting the cable tension is not something you really do for pedal height, you do it to get the right preload on the TOB. For the pedal to change spots you are going to need to go to a double/triple hook quadrant or if you just want it in the stock spot (which is perfect IMO) then get a Max Motorsports quadrant.
If you still have the stock quadrant it is self adjusting and you can grab the pedal and yank upwards towards you and you should hear a zip tie noise which is the adjusting mechanism doing its thing.
Old 01-29-2015, 11:38 AM   #9
Site Sponsor
Sponsor
AMWill's Avatar
Originally Posted by robin_gt View Post
hi folks,
Hey Robin,
Although in most cases there will be no chatter, the fact that you only have 100 miles on the setup leads me to believe that you have nothing to worry about.
Especially since you had your flywheel re-surfaced it most likely needs a better mating surface with the clutch and that could be causing the noise you are hearing.
Hope this helps and keep us updated!
-Will
Toll Free: 866.727.1266
Free Same-Day Shipping!
Old 01-29-2015, 12:26 PM   #10
Panther140's Avatar
Uh oh, that means your clutch is super ****ed up. If I were you, id take it out and mail it to me where I can make sure that it doesnt get in the wrong hands.
Very dangerous stuff going on here, remove it and mail it to me asap! Its for your safety!
Panther140 is offline   Reply With Quote
Old 01-29-2015, 01:50 PM   #11
robin_gt's Avatar
is this a joke?
Old 01-29-2015, 01:53 PM   #12
robin_gt's Avatar
yeah ill try the pedal method first and if that doesn't help ill prob get the quadrant thanks for the advise
Old 01-29-2015, 01:55 PM   #13
robin_gt's Avatar
Originally Posted by AMWill View Post
Hey Robin,
-Will
yea i drove it alot today and it is definitely getting better. thanks
Old 01-29-2015, 05:54 PM   #14
Panther140's Avatar
is this a joke?
No man for real you should mail me that new clutch
Old 01-30-2015, 05:38 AM   #15
robin_gt's Avatar
Yea I just took it out and it's already on it's way to you tracking number says it will be there later today i got next day shipping don't wanna take any chances
clutch slipping and new clutch? iphonemaster93 Pre-2005 V6 Mustang 29 08-06-2012 09:37 AM
clutch clutch... clutch Butch SVT Mustang 4 06-29-2012 03:53 PM
just installed new clutch ram hdx drove about 5 miles and clutch got really hard? Cobra209 SVT Mustang 11 04-01-2012 04:44 PM
If u have air in the break fluid can that make ur clutch pedal feel stiff? bluestorm52 2005-2010 Mustang GT 7 12-10-2011 04:49 PM
proper clutch break-in stangin99 Pre-2005 V6 Mustang 5 05-12-2005 11:40 AM
02:17 PM
