My next mods opinions wanted - Mustang Evolution
Old 01-31-2015, 09:55 PM   #1
Slater2111's Avatar
March build list
LMR List
GT 500 diff cover $147
4R70W trans service kit. $30
AM List
3.73 gear kit $256
Aluminum transmission pan deep sump$150
FRPP rear axle rebuild kit $35
Limited slip spider gears $180
Carbon lok rebuild kit. $108
UPR X pipe $200
July upgrade list
Eibach sport suspension $950 stage 3 Ms has for 899 regular price.
J&M upper control arm. $124
J&M lower control arm. $182
Maximum MS sub frame connectors. $145
Maximum MS CC plates. $210
Steeda bump steer kit. $168
Steeda chrome moly strut brace. $ 158
Polyurethane spring isolators front and rear $55
Is there anything anyone would add or do differently?
My overall goal for the car is strip with some street. But for now it'll be a daily. I just want to do it once and have it done.
Sent from the mothership.
Slater2111 is offline   Reply With Quote
Old 02-01-2015, 08:22 PM   #2
Slater2111's Avatar
No one?
Old 02-01-2015, 08:51 PM   #3
The_Chech's Avatar
Your building your car for 1/4 mile drag days and daily fun driving around right?
Oxford White Roush Stage 1 SN# 6925--SOLD but never forgotten!
Kona Blue GT premium - Slammed on BC's and BMR's full rear suspension
The_Chech is offline   Reply With Quote
Old 02-02-2015, 04:43 AM   #4
Slater2111's Avatar
Yes. I just saw yesterday that Maximum Motorsports has a complete kit on their website. It doesn't use upper control arms in favor of a pan hard bar. I have read that a pan hard bar is the way to go over upper control arms. I just want opinions and info from people that may have what I want. For now it's going to be a street car. It'll slowly progress into a strip car.
Old 02-02-2015, 06:19 AM   #5
The_Chech's Avatar
I have the Panhard bar and I can tell you it's a major improvement for sure if you get their subframe connectors and then the torque arm you will have an amazing set up for both the street and strip. That set up will be far better then J&m's upper and lower control arms for sure.
Old 02-02-2015, 07:23 AM   #6
I suggest doing the full chassis re enforcement kit as one of the first few mods. It comes with the web kit and subframe connectors which are a huge improvement. You can literally feel the solidness in the chassis
tsteevs_foxbody is offline   Reply With Quote
Old 02-02-2015, 07:42 AM   #7
Slater2111's Avatar
Is the torque arm difficult to install? I have access to a lift but can only work on it Friday and Saturday as Its a daily driver to school 35 miles each way.
Old 02-02-2015, 08:17 AM   #8
The_Chech's Avatar
The subframe connectors will be harder to install I believe then the torque arm. Soccer will know more about this set up because that's what he's running. I just need to get my subframe connectors welded on then I'll be ordering this set up.
Old 02-02-2015, 08:28 AM   #9
Subframes you have to weld on, HAVE to. Laugh and point at anyone who has "bolt on" ones. PHB I've never done but I hear its not super hard but not super easy either.
You have an automatic so you should be doing the J-mod to your trans. Not sure what the LMR "trans service kit" is but I'm not sure what it could be for that price. Basic trans service is a new filter and new fluid...
Never use other than stock upper control arms on a pre-05 car btw. They will induce horrible snap oversteer and can wreck the torque boxes even if they are welded. The correct fix is the PHB or a Watt's link or swapping to an IRS.
Old 02-02-2015, 08:41 AM   #10
Slater2111's Avatar
That's what I have heard about other than stock upper control arms. I have already taken them off my actual parts spread sheet. As far as the trans service kit, yes it is a filter and new fluid. I opted to not have it power flushed because of the miles on it. I have a tuner to raise the line pressure of the tranny. So a J mod I was told was not needed. I will have the money to do whatever I want to do to it come July. As far as performance engine. thatll wait till last and then I'll drop something sexy in there
Old 02-02-2015, 08:43 AM   #11
Slater2111's Avatar
And yes I will have weld in SFC I already have a guy that'll do them for $60
Old 02-02-2015, 11:41 AM   #12
rocknbronco's Avatar
What about beefing up the transmission?
A larger cooler, a better suited torque converter, a shift kit, or more race oriented shifter?
Definitely brace it up and if it's feasible go for a roll cage, once again welded not bolt in.
Mustang wanted for here...
rocknbronco is offline   Reply With Quote
Old 02-02-2015, 12:06 PM   #13
July needs X2 balljoints. Very important.
http://www.steeda.com/steeda-x2-must...-kit-555-8101/
Old 02-02-2015, 01:50 PM   #14
Slater2111's Avatar
The transmission is just getting the deep sump pan, new oil and filter. I have the trans tunes by MPT. As far as torque converter, I don't want to waste my money on the transmission too much seeing as I can't use it with a coyote engine as far as I'm aware. If I'm wrong please let me know.
Full roll cage won't happen either until it's for the strip. Also I'm nearly disabled from being in the marines so I don't want to have to climb over a roll cage to get in. Yet...
Old 02-02-2015, 01:51 PM   #15
Slater2111's Avatar
I have seen them. What specifically do they improve? I'm all for better parts. If yall see something I'm missing or something isn't up to snuff let me know.
Old 02-02-2015, 03:14 PM   #16
Thank you for your service!
Old 02-02-2015, 05:26 PM   #17
Slater2111's Avatar
I thought the steeda bump steer kit would correct what the X2 does?
Old 02-03-2015, 09:10 AM   #18
Slater2111's Avatar
Does anyone know if I got a K member brace if a coyote motor would fit in it? Or I was thinking about a 5.4l motor
Old 02-03-2015, 12:45 PM   #19
The_Chech's Avatar
Think you need a new k member that's made just for the coyote motor to be swapped into our cars
Old 02-03-2015, 01:28 PM   #20
Slater2111's Avatar
Ok I think a 5.4 would be a direct fit tho. Am I right?
Old 02-03-2015, 03:30 PM   #21
No, they work together.
Old 02-03-2015, 03:33 PM   #22
No, the X2 balljoints place the positioning back to stock location after lowering car.
Read Below From STEEDA for explanation:
-Any time you alter the height of your ride, as you do when you install lowering springs (like our Steeda Sport Springs), you upset the suspension geometry. Your roll center geometry as well as your bump steer geometry is affected. You can easily bring your front roll center geometry with a set of our X2 ball joints.
Steeda's X2 Balljoint improves suspension geometry on lowered Mustangs by raising the spindle relative to the balljoint pivot-point. This raises the roll center back into thet range for optimum handling, resulting in reduced body roll, quicker steering response and improved overall front tire grip. Steeda's special balljoint reduces the need for oversize front swaybars and allows the use of lower front spring rates, creating more grip over uneven pavement and better ride quality
- See more at: Steeda 1994-04 Mustang X2 Balljoint Kit - Made in USA 555-8101 - Free Shipping!
Old 02-03-2015, 05:03 PM   #23
Slater2111's Avatar
Ok. So the bump steer kit is still needed
Old 02-03-2015, 05:57 PM   #24
thyreaper's Avatar
The jmod is still good for the trans it allows more volume of fluid to run through the valvebody , the jmod in conjuction with a tune to increase pressure you would have near instant shifts and the jmod actually helps the life of the trans, id still do it if i where u
thyreaper is offline   Reply With Quote
Old 02-03-2015, 06:24 PM   #25
Slater2111's Avatar
I don't know if I can justify it or not. I am undecided on the engine and tranny as it is.
Old 02-04-2015, 05:21 AM   #26
The_Chech's Avatar
It is but the 5.0 isn't
Old 02-04-2015, 06:09 AM   #27
Slater2111's Avatar
I think I will go with a 5.4. They are pretty abundant here and can be had for cheap. Building them is pretty easy I have heard. I'll just have to do some reading. Anyone have any knowledge building them? Or have a build thread they can point me to?
Old 02-04-2015, 08:05 AM   #28
Lorraine's driver
ab_mach1's Avatar
I've been wanting the MM subframe connectors too. What kind of shop do you think would weld this in? Even tho you can tell it has them when driving, the Mach 1's are puny and bolt on.
IG: @azurebluemach
Instagram: @ab_mach1
Old 02-04-2015, 08:46 AM   #29
Slater2111's Avatar
Most custom exhaust shops would be able to weld them in. Just make sure they do it on a drive on lift.
Old 02-04-2015, 08:52 AM   #30
Slater2111's Avatar
Old 02-04-2015, 03:50 PM   #31
Slater2111's Avatar
Finally decided on a block to swap in. Mod max racing has their built short blocks. 5.4l high voltage lightning short block. I have decided on that with the coatings on the Pistons and forged I beam con rods with 6cc dished Pistons with 2v relief cuts. I also decided on modular head shop stage 3 ported 2v heads with the GT super car followers and the 2.5 level cam. Also includes titanium springs and retainers. Should be a pretty stout motor.
Old 02-04-2015, 04:27 PM   #32
Mile high JDF's Avatar
What intake are you going to run with that?
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 02-04-2015, 04:39 PM   #33
Slater2111's Avatar
I want to keep it NA also decided on that. I think I could get some impressive numbers out of the block and head. I haven't found a great intake yet but am open to suggestions.
I have read about Sullivan intakes maybe this would be good.
Another possibility is getting some 4v cobra heads and sending them to MHS to have them worked.
The possibilities are endless it seems and I am very back and forth on things. Lol
Old 02-04-2015, 06:50 PM   #34
Lorraine's driver
ab_mach1's Avatar
Thanks, I'll look into those locally.
IG: @azurebluemach
Old 02-04-2015, 07:25 PM   #35
Yes, and CC plates.
-You will have a superbe system. It will perform fantastic. And, done the right way. Its a beautiful thing zinging around off passes stuck to the ground, like a rail, effortless control and decent speeds.
Need opinions on next mods! Deep_Impact 2011-2014 V6 Mustang 5 11-27-2013 12:40 PM
MODS MODS MODS! S197Miller 2005-2010 Mustang GT 28 02-10-2013 01:36 PM
Mods.....Mods.....Mods.... Srohda 2011-2014 Mustang GT 8 06-01-2012 12:50 PM
Custom mods to the stang *opinions wanted* mysteed Mustang Audio & Video 27 12-09-2005 08:06 PM
Opinions wanted RaceGirl007 Pre-2005 V6 Mustang 11 02-04-2004 07:50 PM
06:18 PM
