Looking to bolt in a 2004 cobra engine/trans/driveshaft - Mustang Evolution
Old 02-02-2015, 01:08 PM   #1
TxHxE MadHatter's Avatar
Basically I hav a 2001 GT with a snapped rod that I scored for $800, and a full 04 cobra setup with all the wiring harnesses up til the end of the driveshaft- now I kno some ppl usually do solid axel swaps in their 04 cobras, but I'm planning on having this bolt directly to the GT solid rear, and I was wondering what I would need to build the rear up enough to handle to cobra drivetrain. I'm planning on going with 31 spline axels and upgraded gears, but do I need anything off the cobras IRS differential housing to make it bolt to the driveshaft correctly? Any info is greatly appreciated, thanks
TxHxE MadHatter is offline   Reply With Quote
Old 02-02-2015, 06:37 PM   #2
Mile high JDF's Avatar
You can do it one of two ways. Either swap the pinion flange from the Cobra differential or get a GT driveshaft flange and a hybrid u-joint
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 02-02-2015, 10:21 PM   #3
Alright I'll probably just swap the cobra pinion flange from the cobra diff since I'm goin to be ripping the GT axel apart as it is to swap in the 31 spline mosers, 31 spline ford racing trac LOK limited slip dif with carbon discs, and 3.73's- but now I'm wondering what bearings and seals I'm supposed to use for the 31 spline moser axels, becuz I feel like I'd need bigger ones than the regular ones that are on with the 28 spline axels, the SR Performance 31 spline axels come with bearings and seals, but the mosers don't, so I'm confused as to which bearings and seals I'll need
Old 02-02-2015, 10:23 PM   #4
Best bet is to see what Moser recommends for some like that
Old 02-03-2015, 07:29 AM   #5
phillip433's Avatar
I just completed mine and I had to remove one side of the ujoint on the cobra drive shaft and get some kind of combination ujoint so it will fit the flange on the stock gt rear end
2003 True Blue mustang gt
phillip433 is offline   Reply With Quote
Old 02-03-2015, 08:14 AM   #6
Yeah I could probably do that with the GT flange on the cobra driveshaft in the meantime just to get it running, not like I'm gonna start beating it up til after I build the rear so when I do all of that I'll swap to the cobra flange out- thanks for the help guys and if anybody else knows about the moser bearings and seals for 31 spline I'd appreciate it, I'm gonna try to find out from moser but somebody here might kno also lol
2004 cobra
WIN A 2015 Driveshaft Shop Driveshaft & Half-Shafts at AmericanMuscle! AMAlexLazarus 2015 Mustang GT 13 02-22-2015 02:54 PM
Upgrade Your Weak Stock Driveshaft with The Driveshaft Shop at AmericanMuscle AMWill AmericanMuscle 1 03-16-2014 02:18 PM
trans/driveshaft 90fox 1979-1995 Mustang GT 5 10-04-2013 10:28 PM
3 bolt or 4 bolt camber plates Venomouz831 Pre-2005 V6 Mustang 9 12-22-2011 01:34 AM
wtt or sell 6 bolt aluminum flywheel for 8 bolt Everett Mustang Parts for Sale and Wanted 32 02-19-2011 09:22 PM
12:50 AM
