Eaton supercharger? - Mustang Evolution
Old 02-04-2015, 09:53 AM   #1
SquatchMan's Avatar
Eaton supercharger?
Name:	ImageUploadedByMustang Evolution1423068776.280617.jpg
Is this worth $350? And what else would I need?
40th Anniversary GT
04 GT
SquatchMan is offline   Reply With Quote
Old 02-04-2015, 10:08 AM   #2
Mile high JDF's Avatar
That's about the average price for one of those. You're going to need a $2k+ adaptor kit from Tork Tech to make it work along with fuel system upgrades and a tune
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 02-04-2015, 10:11 AM   #3
SquatchMan's Avatar
Welp that sucks lol
40th Anniversary GT
04 GT
Old 02-04-2015, 10:32 AM   #4
Panther140's Avatar
Get one of those, get an intake adapter, and then put a carburetor on it like a draw through setup. EFI sucks cock as far as trying to modify goes.
I have seen people put an eaton m-95 supercharger on a ford 200 6 cylinder with a carburetor adapted to the back of it. The supercharger sucks your air fuel mix through it and then forces it into the engine.
WAYYYYY cheaper than going with the EFI route and you can tune it yourself at the gas station with a screwdriver.
It works well with the EAtons because the bearings in the eatons are sealed off from the passages that the air travels through. That way the fuel doesnt wash the bearings dry. Plus think about it, why would you put bearings in an area where they would be exposed to boost? Thats going to blow the grease out of the bearings.
Oh and another thing, the air fuel mix flowing with the air reduces the need for an intercooler. That is because air mixed with fuel is like 20% cooler than just raw air. Thats nother reason that carbs make more power than EFI. Another reason is that the fuel gets atomized dramatically better since it spends more time suspended in the air.
The one and only downside to a carb as opposed to EFI is that it doesnt self adjust for temperature. They DO self "adjust" for a situation that involves your engine making more horsepower. They meter fuel based on amount of vacuum
Panther140 is offline   Reply With Quote
Old 02-04-2015, 10:50 AM   #5
That sounds like a retarded idea to me. Where are you going to mount the carburetor? What are you gonna do about fuel distribution to the various cylinders? If you're gonna drop $3k+ on a supercharger setup why half *** a carb install on it when you can get better drive ability and reliability out of an efi setup?
Old 02-04-2015, 11:34 AM   #6
Panther140's Avatar
The fuel gets distributed to the cylinders the same way air is distributed to the cylinders, by volumetric demand.
You mount the carb to the supercharger.
You dont need to spend 3k on it either.
All you need to do is mount the supercharger to the intake, mount the carb to the SC'er, and put a belt over the pulley. Then adjust timing via CDI box.
http://www.hotrodders.com/forum/eato...-178431-3.html
Old 02-04-2015, 12:05 PM   #7
smurf stang's Avatar
Mustang Supercharger Kits, GT, Cobra | Tork Tech
Not a simple budget plan but a little cheaper I guess.
2016 VW GTI 2.0 Turbo
Old 02-04-2015, 05:14 PM   #8
Panther140's Avatar
Holy **** balls. $2500 for an intake manifold, intercooler, and a belt tensioner?
---------- Post added at 06:14 PM ---------- Previous post was at 06:13 PM ----------
I could literally buy a welder, take a welding class, and get some of my own aluminum for that price.
---------- Post added at 06:14 PM ---------- Previous post was at 06:14 PM ----------
Old 02-04-2015, 05:22 PM   #9
That's actually not a bad price.
And just to let you know force induction in a homemade intake is a very bad idea.
Go away fat man...
-Stewie
Recon is online now   Reply With Quote
Old 02-04-2015, 08:45 PM   #10
Panther140's Avatar
Go away fat man...
-Stewie
I guess I could see how it would be easy to screw up. The right amount of effort and I think you could make something that can hold 10-15 psi pretty easily. Ive seen more impressive feats
Old 02-04-2015, 08:55 PM   #11
Speaking from personal experience...
You might not know how incredibly easy it is to improperly weld part of the intake. With 10 lbs of boost it broke the intake and forced metal into the heads, causing one intake valve to make contact with the piston. Puncturing the piston and causing chunks of metal to break the crank. While having the piston slam into the cylinder wall and busting a hole in the block. We literally destroyed the engine... (Boss 520)
Long story short...
BUY A FORCE INDUCTION INTAKE!!!! DONT MAKE ONE!!!!
Go away fat man...
-Stewie
Old 02-05-2015, 06:49 PM   #12
Cheapest/best budget way to put a blower on a Mustang is a Vortech S trim. And then you have to make sure the rest of the vehicle is setup for the power. Plenty of dyno queen cars on stock/stockish suspension that will get their asses handed to them in a race by a car making a lot less power but properly setup.
Old 02-08-2015, 09:34 PM   #13
thyreaper's Avatar
Eaton supercharger?
Yep, spinning aint winning, and a very good carb that could do boost u could easily spend 1k+ for that i could get everything i needed and pay for the tune for 400whp (already did it) and have stockish drivability until i put my foot into it, theres a reason high hp cars are fuel injected and not carb'd ... Id rathar bave it programmed and never have to worry about it even when the temp changes... And efi cars atomize fuel better i dunno where u get ur info from but the only way id ever go carb is if i had a rolling shell and i put together the motor and all ( in which id go a big block chevy high comp with nitrious ..ect) and even then i think id get one of those tuneable systems for 1500 instead of buying a carb
thyreaper is offline   Reply With Quote
Old 02-09-2015, 09:52 AM   #14
Panther140's Avatar
Efi pissing fuel into the port doesn't atomize like a fog of air/fuel being drawn in through a carb then into the intake and then into the port and then into the cylinder.
Adobe Flash Player - Free Software Download | Favdownloads=
The only real advantage to EFI is that it self tunes.
WHere are you getting a tunable EFI kit that comes with injectors, computer, harness, software, tuner, fuel pump, fuel relay, high pressure fuel lines, and Wideband O2 sensors for $1500?
Even so, I got my carb for $100 used, a $30 fuel pump, and some cheap lines. I could get a wideband with a guage and jet the carb to run spot on at all throttle positions. $5 main jets, a $10 step up spring kit, and a $150 O2 sensor kit. The best part is, a carb will never leave you totally stranded like EFI has done to me so many times.
Ever hear of an issue like PATS malfunction on a carbureted car?
Old 02-09-2015, 11:51 AM   #15
thyreaper's Avatar
Eaton supercharger?
U can get pgm efi systems for 1500 i saw some in the magazine, they are the units that look like carbs but have injectors in them and yes it comes as a full system that's programable..... And u leave ur in tank pump alone unless ur going for the big leagues.....Thats the closest id get to a carb, and injectors dont piss fuel if u have good injectors they should be spraying a mist not a straight stream of fuel , and with the new efi systems nowadays u can do boost by gear in which ur tune would be different for each gear as the more boost u give the motor in a higher gear the more fuel it will need, try doing that with a carb it wont happen, like i said theres a reason top fuel cars, indy cars...ect have fuel injection motors....
Old 02-09-2015, 01:10 PM   #16
Panther140's Avatar
Nascar does plenty fine with carbureted fuel metering. And look at how much power the sport bikes made with carbs. 140 horsepower per liter BONE stock 17 years ago. Then they got EFI and didn't gain any horsepower..
Or my Dirtbike.. 200 horsepower per liter using a carb and like 3 moving parts in the engine.
Old 02-09-2015, 01:26 PM   #17
Oy, here we go pissing match...
Old 02-09-2015, 01:28 PM   #18
natestang07's Avatar
I can pee better than you and I know it!
Old 02-09-2015, 01:40 PM   #19
I just had like 3 cups of coffee and a monster because #monday.
Old 02-09-2015, 01:44 PM   #20
Slater2111's Avatar
Still haven't seen your carb swap run, Panther...
Sent from the mothership.
Slater2111 is offline   Reply With Quote
Old 02-09-2015, 01:48 PM   #21
Shoot monster is game over when it comes to the bladder lol
Old 02-10-2015, 12:04 PM   #22
Panther140's Avatar
Yeah cuz it looks janky as **** lol. I need to get a legit adapter for my intake, not the wooden one that I have on it now lmao.
Treo of Shelby's in Easton, Pa SLDGT500 Shelby Mustang 9 01-01-2014 08:33 AM
Next Gen Electric Supercharger??? Rellik Pre-2005 V6 Mustang 31 10-13-2003 07:03 AM
supercharger el cheapo Pre-2005 V6 Mustang 0 08-20-2003 10:34 PM
$200+ complete supercharger, help Stang01 Pre-2005 V6 Mustang 3 07-20-2003 04:07 PM
Supercharger or Nitrous? ERICK Pre-2005 V6 Mustang 8 05-12-2003 02:41 PM
09:20 PM
