Drag Radials on stock 5 Speed GT? - Mustang Evolution
Old 02-05-2015, 08:46 AM   #1
Panther140's Avatar
So I decided that I cannot afford any power adders or anything that's going to add real HP to my car, but I still want to accelerate faster..
If I put some drag radials on, would I get noticeably better 0-30 times? The majority of the workout my car gets is messing around with my friends doing 0-60 pulls out in the middle of nowhere. Theres also a giant car event coming up in the Wisconsin Dells called Automotion and I want to be able to launch faster than usual.
My car makes about 25 hp more than stock right now, so what kind of RPM would I be able to launch at with some decent tires?
Panther140 is offline   Reply With Quote
Old 02-05-2015, 03:47 PM   #2
The_Chech's Avatar
You need suspension work to make the car grip better a new tire alone won't achieve that
Oxford White Roush Stage 1 SN# 6925--SOLD but never forgotten!
Kona Blue GT premium - Slammed on BC's and BMR's full rear suspension
The_Chech is offline   Reply With Quote
Old 02-06-2015, 03:26 AM   #3
I could be wrong, but I thought with a good sticky tire, there is a possibility of breaking the rear end. Someone correct me if I'm wrong.
03redzo6 is offline   Reply With Quote
Old 02-06-2015, 04:03 AM   #4
The_Chech's Avatar
Don't think so if the car is close to stock maybe is it was cammed way the hell out or has a power adder
Old 02-06-2015, 09:50 AM   #5
Panther140's Avatar
Yeah I think I should just focus on suspension. What is the cheapest way to make the rear end hook up good in a straight line off of a launch? I cant afford to just get all kind of suspension work done
Old 02-06-2015, 10:08 AM   #6
Slater2111's Avatar
Start with some good rear lower control arms. Don't get solid poly bushings either.
Sent from the mothership.
Slater2111 is offline   Reply With Quote
Old 02-06-2015, 11:21 AM   #7
Panther140's Avatar
Im pretty sure that a tire with a stickier compound, softer sidewall, and bigger contact patch is going to bring real improvements. How could it not?
Old 02-06-2015, 12:08 PM   #8
The_Chech's Avatar
Because the suspension is going to flex and pop causing the rear tire to loose traction
Old 02-06-2015, 12:11 PM   #9
The_Chech's Avatar
If you look at the control arms in the rear, they're cheap stamped pieces of metal. That's why most that actually make a good lower control arm are tubular with either a solid metal bushing or poly bushing in design so there is no way of it to flex like the stamped stock ones with rubber bushings.
Old 02-06-2015, 02:11 PM   #10
The_Chech's Avatar
Double post......
Old 02-06-2015, 03:12 PM   #11
Panther140's Avatar
Ohh I see now. Yeah that sounds retarded. A rubber bushing and stamped control arm?
Im used to dirtbikes where we had swingarms that could take landings from 50' high on a regular basis lol. So it didn't even occur to me how cheap they made these ones.
Old 02-06-2015, 09:40 PM   #12
That's good to know
Old 02-06-2015, 11:26 PM   #13
Speed_Mister's Avatar
Region: Arkansas
Your rearend will be fine, unless you do a 4k+ rpm launch. But yes with drag radial you are more likely to break something, rather than slicks which would wrinkle absorbing most of impact.
2004 Mustang GT 5 Speed Full Bolt On 360rwhp 440rwtq
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 02-07-2015, 09:48 PM   #14
Panther140's Avatar
Will slicks grip the road better? Id rather have slicks tbh. Im not going to daily drive with slicks or drag radials id just put them on when I go to car meets or when I need to go fast
Old 02-08-2015, 11:30 AM   #15
Yes. They will!
Of course, doing the whole suspension, you would get the maximum benefit from the tires, but, for sure, the tires are going to help.
The clutch should always be the weak link in the drivetrain, on a street car anyways. Wouldn't it be better to limp your car home from the track, with a burnt out clutch, than to have to tow it home with a broken transmission, drive shaft, differential, axle, etc?
Old 02-08-2015, 03:15 PM   #16
Region: Arkansas
Ehh. I drove on slicks some when I was young and learning it's okay for easy driving wouldn't recommend it. But when it rains you're screwed. I was literally losing traction on cruise control going 55 with slicks on, I had to slow down to like 30mph. Of course if you heated the tires up they hook ok especially if you prep the street and tires with track bite. But we ain't about that street racing here so don't do that. I'm sticking with drag radial actually just because I know I will drive the car to car meets and to the track. But radials especially on a 17inch rim are asking to break differentials, axles, and ripping out control arm bushings. I would do the 15 inch rim with mt streets. It's a 275 tire with a lot of sidewalk and sticky tires is all you need. I know 1000rwhp cars on nitrous use this tires. And yes you can still break stuff with 15 inch rim on radials just more people get away with it than 17inch rims with radials to and with slicks it's not very common to see people break stuff. Get the 15 inch rim radials mt streets 275. They are cheap tires for the size also at the right places.
Full Bolt Ons
370rwhp 470rwtq
Old 02-08-2015, 03:17 PM   #17
Region: Arkansas
Originally Posted by straybullitt View Post
Yes. They will!
Yes. I'm on the factory clutch with 93,000 miles and 370rwhp. My clutch hates me after I hot lap the car. I should probably invest in a new rearend, and clutch before I destroy everything with radials.
Full Bolt Ons
370rwhp 470rwtq
Old 02-09-2015, 01:03 PM   #18
thyreaper's Avatar
What power adder u have to get 370 rwhp? Stock with just reg boltons wont get that #
thyreaper is offline   Reply With Quote
Old 02-09-2015, 01:24 PM   #19
Panther140's Avatar
Yeah 370 is pushing it, especially rwhp lol. 360 rwhp and 440 rwtq? That must be a long list of bolt ons lol. Does nitrous count as a bolt on in your book? lol
Old 02-09-2015, 04:44 PM   #20
Region: Arkansas
Nah I'm on a ebay turbo kit.
---------- Post added at 06:44 PM ---------- Previous post was at 06:43 PM ----------
Actually I'm all motor..
---------- Post added at 06:44 PM ---------- Previous post was at 06:44 PM ----------
Unless my alternator supercharger starts whining then I tell people it's supercharged.
Full Bolt Ons
370rwhp 470rwtq
Old 02-09-2015, 04:46 PM   #21
Region: Arkansas
Okay yeah I'm on nitrous. I like to keep it running lean. Like 11.8-11.7 a/f lean. 😁
Full Bolt Ons
370rwhp 470rwtq
drag radials on v6 rims, kumho's on black bullitts whipster24 Mustang Parts for Sale and Wanted 2 01-19-2006 05:20 PM
16x8 wheels for drag radials whipster24 Mustang Parts for Sale and Wanted 5 09-04-2004 10:02 AM
F/S: BFG P275/50/R15 Drag Radials for Sale KrazyPony Mustang Parts for Sale and Wanted 27 06-20-2004 04:23 PM
wtb bfg drag radials johnnybgood Mustang Parts for Sale and Wanted 0 06-09-2004 07:18 PM
F/S: BFG Drag Radials 15" P275/50/R15 KrazyPony Mustang Parts for Sale and Wanted 3 02-11-2004 05:14 PM
10:44 AM
