Help - Mustang Evolution
Old 02-08-2015, 09:51 PM   #1
Help
Hi Is normal if the clutch sits about 1 inches higher than the brake pedal
And another question
When i want to put on reverse gear
Sometimes is hard and i hear like grindin sound
Mich is offline   Reply With Quote
Old 02-08-2015, 09:56 PM   #2
The pedal is normal. And your reverse gear it could be the synchro going bad.
Adventure till you drop
Old 02-08-2015, 09:58 PM   #3
Can i drive like that or i need to fix the sync...
Old 02-08-2015, 10:02 PM   #4
It shouldn't hurt, if it gets any worse then replace it. My chevy has been doing it for years. Just bring the rpms off idle when you put it in reverse and it should go in smoothly.
Old 02-08-2015, 10:07 PM   #5
Thanks for the help
Old 02-08-2015, 10:08 PM   #6
Anytime, nothing else wrong or any mod questions you have?
Old 02-08-2015, 10:17 PM   #7
No thats the only problems
But i have other question when i put Ac and the defrost
The rpm goin up and down
Old 02-08-2015, 10:18 PM   #8
That's also a common thing when the A/C is turned on the engine works a little harder, so the rpms fluctuate a little.
Old 02-08-2015, 10:18 PM   #9
natestang07's Avatar
Continuously or does it stop?
Old 02-08-2015, 10:25 PM   #10
Im aways use the defrost when it was raining but one day star to make that problem
It Continuous it go like 1500 rpm down and it will not stop an till i turn of the defrost or ac
Old 02-08-2015, 10:27 PM   #11
Maybe your alternator is starting to go bad and you are overloading with the accessories. I don't know ask recon he knows quite a bit
Old 02-08-2015, 10:30 PM   #12
Help
That's a possibility, one way to check the alternator is taking it to a shop and checking the voltage drop. It will show you if it's going bad, I believe parts stores can do it too.
Old 02-08-2015, 10:31 PM   #13
Thanks guys for the help
Old 02-08-2015, 10:37 PM   #14
Another way is a high quality battery charger, the easier of the two. You can hook it up and monitor the battery voltage and charge. If it lowers at an idle or the charge drops then the alternator is going out. I'm an auto tech by profession, those would be the methods of use. Should I be giving this info out for free? I might lose some business...
Old 02-08-2015, 10:39 PM   #15
Not like it is info you can't find on Google lol
Old 02-08-2015, 10:44 PM   #16
That's true. I learned through trail and error, not the best method. The interesting thing is most of the local shops in my area wouldn't know this. I found that out one fella came to our shop after spending close to a grand and it turned out the alternator was bad.
Old 02-08-2015, 10:46 PM   #17
That is definitely the way my dad and I went about it. If you plug your phone into a charger and the battery percentage goes down your charger is bad. Same concept as an alternator lol
Old 02-08-2015, 10:50 PM   #18
At the time, me and my know it all self, tried it and failed (know it all teenager syndrome= KIATS). Best method ASK SOMEONE WHO'S ALREADY TRIED IT!! Aka my boss...
Old 02-08-2015, 10:51 PM   #19
Luckily my uncle runs a mechanic shop and my dad was quite the gearhead when he was younger so ki get quite a bit of help
Old 02-08-2015, 10:58 PM   #20
My entire (both sides) family's profession is automotive related. My boss is my pops, 45 years experience. I'm a fourth generation auto tech, 16 years and counting. What can I say cars are our lives. Every holiday get together we're in the garage working on something, 4-6 hours later we go do that holiday customs. But help is always the best tool...
I think I win lol...
Old 02-09-2015, 08:04 AM   #21
Billgluckman's Avatar
I'm pretty sure reverse is not synchronized. I know mine doesn't go in like it should. It's common.
Billgluckman is offline   Reply With Quote
Old 02-09-2015, 08:43 AM   #22
Brentap19506's Avatar
I used to have a problem with my reverse too. Here's a trick you can try that works for me 100% of the time but until you get used to doing it quickly, it could be annoying. if it is fighting to go into reverse: let the clutch out, put clutch in, go into 1st, go into reverse. Works every time for me and I've had bad reverse for over 2 years.
2000 Gt- Vortech V1 10psi, 4.10 gears, SLP LT headers, Magnaflow cat-back, Eibach pro-sport suspension, MM subframes, 78mm plenum and throttle body, lots of cosmetics, and more
Brentap19506 is offline   Reply With Quote
Help Help Help....mustang Princehollie Pre-2005 V6 Mustang 57 03-17-2015 04:58 PM
Help Help Help....1995 mustang 3.8 Princehollie Pre-2005 V6 Mustang 4 07-03-2014 06:42 PM
Baltimore area spark plug insert!! Help Help HELP readytorockyou 1996-2004 Mustang GT 0 04-25-2010 11:37 AM
Help help- fuel pump-help! The Darkside Pre-2005 V6 Mustang 26 05-08-2009 01:45 PM
Help help help? Seph Mustang Audio & Video 6 02-15-2004 04:35 PM
01:25 PM
