02 GT - Clicking sound - Mustang Evolution
Old 02-09-2015, 01:16 PM   #1
In 1st gear and when taking off (not high speed), there is a clicking sound coming from what seem middle to rear location. It also makes a similar sound if im sitting at a stop and I don't have the clutch pinned to the floor...it will make a clicking sound.
Clutch?
Aaron636r is offline   Reply With Quote
Old 02-10-2015, 05:00 AM   #2
Almost sounds like a possible pilot bearing. When you disengage your clutch is when the input shaft recedes out of the pilot bearing and when your clutch is engaged is when it re inserts back into the pilot bearing. Sorry for the long winded explanation. You hearing it when it is engaged tells me thats the most probable cause.
clinesr22 is offline   Reply With Quote
Old 02-10-2015, 07:25 AM   #3
Thank you. Should I change the clutch while I'm changing the bearing? I don't know the history of the vehicle...so no idea how old the clutch is.
Thanks again for your help.
Old 02-10-2015, 06:12 PM   #4
Typically with that job you want to replace the pilot bearing, thowout bearing, clutch and resurface the flywheel. Is the correct way to do it. Obviosly inspect the shift fork and pivot ball for damage
---------- Post added at 04:12 PM ---------- Previous post was at 04:11 PM ----------
Im sorry clutch fork
Old 02-10-2015, 06:12 PM   #5
Ok, thank you for your input
HELP!!! Whistling sound coming from the front/ engine making a clicking sound. Whitestang23 2005-2010 V6 Mustang 5 07-03-2013 05:36 PM
Clicking sound Gary100288 1979-1995 Mustang GT 8 04-15-2012 09:35 PM
Clicking sound Gary100288 1996-2004 Mustang GT 3 04-10-2012 01:13 PM
Clicking sound?! ColeJohnson 1996-2004 Mustang GT 22 01-12-2012 05:31 PM
How do I fix the clicking sound? twentyis1 Pre-2005 V6 Mustang 1 04-30-2007 01:21 AM
10:55 PM
