Control arms or under drive pullys - Mustang Evolution
Old 02-09-2015, 10:10 PM   #1
I'm not sure whether I should go work on the suspension a bit in the back or spend the money on under drive pullys? I already have full exhaust and CIA with TB and plenum. I don't really want to lower the car because my x pipe already scrapes sometimes.
04sonic is offline   Reply With Quote
Old 02-09-2015, 10:17 PM   #2
Control arms
Old 02-09-2015, 10:20 PM   #3
natestang07's Avatar
If your stock suspension is as bad as mine I would highly suggest taking care of the suspension
Old 02-10-2015, 02:49 AM   #4
How much do you have to work with?
clinesr22 is offline   Reply With Quote
Old 02-10-2015, 06:16 AM   #5
About $400
Old 02-10-2015, 06:47 AM   #6
XSlashDashX's Avatar
I'd get UDP if your suspension is good and not rattling or squeaking.
Old 02-10-2015, 06:50 AM   #7
It's still good I only have 25k on the car
Old 02-10-2015, 01:58 PM   #8
rocknbronco's Avatar
Suspension no doubt get the car the handle and hook as good as possible before making more power.
Mustang wanted for here...
rocknbronco is offline   Reply With Quote
Old 02-10-2015, 02:12 PM   #9
KATO's Avatar
Control Arms will help Plant your Tires on the Ground.
Old 02-10-2015, 05:07 PM   #10
With that you can get sway bars and upper and lower control arms
Old 02-10-2015, 06:08 PM   #11
For now the stock front/rear sway bars are fine. I'd definitely upgrade to some tubular upper/lower control arms and some weld in subframe connectors.
Old 02-10-2015, 09:52 PM   #12
The_Chech's Avatar
Changing uppers in the new edge is a bad idea as it can possibly tear the torque boxes.
Oxford White Roush Stage 1 SN# 6925--SOLD but never forgotten!
Kona Blue GT premium - Slammed on BC's and BMR's full rear suspension
The_Chech is offline   Reply With Quote
Old 02-10-2015, 10:01 PM   #13
I think it depends on the brand/design. I've heard the Maximum Motorsports Uppers can as they still induce flex like the Ford Units, even with the stiffer bushings.
A guy I know from a local club has the Steeda's and claims they are much better on the torque boxes vs the MM ones.
Old 02-10-2015, 10:29 PM   #14
Lorraine's driver
ab_mach1's Avatar
I looked up under my stang when it was on the rack to see where the exhaust was scrapping on speed bumps, even when I was stock height. For mine, it looks to be the design of the off road H pipe I have. Maybe it's like that for you. I was thinking of taking mine to an exhaust shop to see if they could make some adjustments to the angle in the area after the rear O2 sensors and before the flanges to the cat back. Maybe they could cut and re-weld in that area and get it to angle upward a smidge..? Mine hangs down pretty low at the cat back connection compared to how the stock exhaust was.
IG: @azurebluemach
Instagram: @ab_mach1
Old 02-10-2015, 10:33 PM   #15
The suspension may not have rattles or squeaks but it definitely needs help. The suspension in these cars is based off of the 1979 Fairmont. So you can bet it's worse than mediocre stock.
Old 02-11-2015, 05:17 AM   #16
Lorraine's driver
ab_mach1's Avatar
IG: @azurebluemach
^Lol, I could have swore I read that your exhaust scraped OP. My bad
2004 Azure Blue Mach 1
IG: @azurebluemach
Old 02-11-2015, 09:40 PM   #17
Mine only scrapes where the cats are I've had it in an exhaust shop a couple times said it's as high as it will go
Old 02-11-2015, 11:55 PM   #18
How are you guys scraping?
I didn't start to scrape my exhaust until I pretty much slammed mine lol
Name:	ImageUploadedByMustang Evolution1423724116.052298.jpg
Old 02-12-2015, 01:45 AM   #19
Attachment 175242
What are you riding on suspension wise?
Old 02-12-2015, 10:57 AM   #20
The_Chech's Avatar
Uhhh I have side exhaust that's the lowest point on the car and I'm lowered a good 3.5". I scrape more K member then exhaust
Old 02-12-2015, 01:24 PM   #21
There is no design of UCA that works well as the 4 link is just a bad design period.
MM does not sell any UCAs besides stock stamped Ford ones btw. There is a big write up on their site as to why they do this and why using aftermarket UCAs is a bad idea period.
Basically, if you are serious about your car not handling like a pile of doo, you install a TA/PHB setup or a Watt's link OR you convert to IRS but when converting to IRS you can introduce a whole new set of issues if you don't go through said IRS prior to installing it.
For Sale: Bmr upper control arm, lower control arms and relocation brackets blacked out gt Mustang Parts for Sale and Wanted 26 05-30-2014 09:04 AM
lower control arms vs. upper control arms 13 stang22 2011-2014 V6 Mustang 24 05-08-2013 06:03 AM
Underdrive perfromace pullys Artaz 2005-2010 Mustang GT 4 06-10-2012 04:37 PM
under drive pullys? justjake94boss 1979-1995 Mustang GT 4 04-10-2012 12:37 PM
APS Underdrive Pullys Donny B Pre-2005 V6 Mustang 2 12-06-2003 10:41 PM
12:33 PM
