my cluster gauge lights don't work - Mustang Evolution
Old 02-10-2015, 04:54 PM   #1
I just realized that my cluster gauge lights don't work I've had this car for about 6 months and just realized that. I'm assuming the previous owner installed those LED lights and took them out without properly installing back the normal lights does anybody know where I can get the wiring diagram for the cluster gauge light, trying to see if everything was wired right which I doubt he did, the light bulbs are new and I found the switch to turn on and off the LED lights without wires attached.
gt_nez is offline   Reply With Quote
Old 02-11-2015, 02:23 PM   #2
I assume that you have already checked all of the fuses related to the instrument cluster... There are several.
Have you checked to make sure that the dimmer switch, on the headlight switch, isn't turned all the way to "low"?
Is this the original instrument cluster? Pull it out and see if anyone has messed around with the wiring harness. It should be easy to tell if there are any splices or if anything has been moved around.
Old 02-11-2015, 02:31 PM   #3
Yeah that picture shows the lights all the way up the instrument panel is the original but next to the fuse box you seea lot of wires that had been spliced or just dangling and all fuses are good.
Old 02-11-2015, 02:46 PM   #4
Well, you will have to search around for a wiring diagram and try to figure out where/why the power, going to the cluster illumination, is stopping.
You should be able to tell what was done to the factory wiring harness by closely examining it.
I dislike when people add a bunch of garbage to the car and hack up the wiring. It makes it a pain in the *** to diagnose someone elses shoddy work, later on.
Old 02-11-2015, 03:54 PM   #5
Cbird's Avatar
Region: Iowa
To me, it looks like the stock bulbs are still in- and working! I say this because the needles are lit up.
My guess is that the LED overlay is blocking the light from coming through.
Get us a pic of your gauges in the daylight and we can you if it's the factory one or not. If it's aftermarket, just pull it off and your done.
Cbird is offline   Reply With Quote
Old 02-11-2015, 04:26 PM   #6
Here's the panel
Old 02-11-2015, 04:30 PM   #7
natestang07's Avatar
Originally Posted by gt_nez View Post
Here's the panel
Probably something on the back of the faceplate that needs to come off like a sticker or something silly like that
Old 02-11-2015, 04:51 PM   #8
alecas447's Avatar
Same happens to me. But for me only the mph and the rpm ones don't light up
alecas447 is offline   Reply With Quote
Old 02-11-2015, 04:57 PM   #9
That sounds like bad bulbs
Old 02-11-2015, 05:51 PM   #10
alecas447's Avatar
Yea I just turn it all off looks better imo
Old 02-11-2015, 07:33 PM   #11
Cbird's Avatar
Region: Iowa
Here's the panel
That's a aftermarket overlay. Just get into the cluster (very easy) and pluck it off. Good as new the only bummer is the stock gauges are just a basic black color.
Or you could always look into another one to replace it with, since the white gauges look really good.
Old 02-11-2015, 10:39 PM   #12
alecas447's Avatar
Here's the panel
I hate that one. That's the exact same one I have. The red line is not even right
Fog lights don't work antnvlz1294 1979-1995 Mustang GT 11 12-06-2014 09:11 AM
2014 V6 Base Cluster to Premium Cluster sid719e 2011-2014 V6 Mustang 11 08-17-2014 12:23 AM
2005 4 gauge cluster upgrade to 6 gauge wessstblvdd 2005-2010 Mustang GT 6 07-07-2014 08:29 AM
gauge cluster lights formulaDstang 2011-2014 V6 Mustang 2 04-27-2012 10:43 PM
Just so you don't think I don't take care of my car.... 97Stallion Pictures and Videos 15 10-10-2004 11:30 PM
08:44 AM
