Shaking - Mustang Evolution
Old 02-11-2015, 08:11 PM   #1
02_gt's Avatar
Shaking
I just got some new wheels and tires and now between 60 and 70 mph I have a bad shaking coming from the back of the car. Anyone ever had this happen
02_gt is offline   Reply With Quote
Old 02-11-2015, 08:32 PM   #2
Most likely the wheel balance is out. Wherever you had them installed should take care of it or be able to check to see if it is out
clinesr22 is offline   Reply With Quote
Old 02-11-2015, 09:14 PM   #3
Steve96's Avatar
Like clinesr said It's most likely a balance issue. I have had this on the front before. I think the MPH that I read years ago where you will feel unbalanced wheels is between 65-68mph. It should get worse and may even out a little when you go under or over those speeds.
1996 GT
Old 02-11-2015, 09:27 PM   #4
Holy **** i have the same problem. I got some new tires and from around 55 to 60ish it starts to shake
Old 02-12-2015, 01:47 PM   #5
Go back to the tire shop and tell them to fix it and ask if they have anyone working there that does not suck at using the balancer.
Old 02-12-2015, 06:08 PM   #6
Thats a nice way for them to **** some **** up lol
Old 02-16-2015, 04:23 PM   #7
02_gt's Avatar
Well I bought new tires fixed a messed up tie rod had tires balanced and aligned. And I still have the shaking prob
Old 02-16-2015, 05:21 PM   #8
Just one tie rod or both
Old 02-16-2015, 05:37 PM   #9
02_gt's Avatar
One it was loose. The other one was still tight.
Old 02-16-2015, 07:38 PM   #10
From what i know is that if one is bad then the other is on its way out too
Old 02-16-2015, 09:17 PM   #11
Typically when i replace suspension parts i would recommend both ie tie rods. But there are actually 4 tie rods. 2 inner 2 outer one of each on each side. Not trying to insult your knowladge on suspension. But your ball joints may also be worn. And well as your hub assembly. If you do some research look for a shop that has a good name and maybe even try auspension specialist
2000 mustang 3.8 shaking klwiese2 Pre-2005 V6 Mustang 7 04-11-2010 03:07 PM
Shaking McGrail482 Pre-2005 V6 Mustang 4 12-12-2006 02:55 PM
shaking 5.0homustang 1979-1995 Mustang GT 5 04-10-2006 09:28 PM
shaking problem at 60mph timekiller Pre-2005 V6 Mustang 6 03-19-2006 12:48 PM
Shaking above 55mph any ideas? SpectorV Pre-2005 V6 Mustang 11 07-20-2004 09:44 AM
10:27 PM
