Compression test results concerning and issues after build - Mustang Evolution
Old 02-11-2015, 11:07 PM   #1
In short, I just finished putting in CMS stage 3 blower cams and max lift valve springs, timing chain slipped and I didn't realize it and bent some valves. I took my heads off had them ported polished valves redone and a valve job. I put everything back together with all new gaskets and bolts and tried to start the car but it just cranked and didn't start. My spark plugs are not sparking. I checked all fuses, replaced crankshaft position sensor, and still nothing. Any ideas on what that could be? Also I checked my compression and all cylinders were between 75 and 85 does this seem right with my set up? I've never checked the compressing when it was running so I have no idea what it was before adding the cams. This set up has about 2500 miles on it. I have a 2002 4.6 2v stroked to a 5.0 with forged Manley internals 8:1 compression ratio, stage 3 cms blower cams, vortech v1 15psi pulley, and ported and polished stock pi heads heads. I have ran this set up with no issues for a while and except with stock cams and a 10 psi pulley.
Sent from my SAMSUNG-SM-N900A using Mustang Evolution mobile app
taylorboy54 is offline   Reply With Quote
Old 02-13-2015, 12:13 AM   #2
Just wanted to update everyone. I did a wire tuck during this build and one of my connectors in the fender was loose. I connected it completely and the car fired right up and sounds amazing. I have not checked the CR yet to see if it has raised since I got it running.
Old 02-13-2015, 12:15 AM   #3
Good to hear it's fixed. Now post a video and let's hear that cam!
Adventure till you drop
Old 02-13-2015, 01:14 AM   #4
Can i get a pic of the wire tuck if you dont mind
clinesr22 is offline   Reply With Quote
Old 02-13-2015, 08:05 AM   #5
Yes I will get a pic posted and a video of it running today.
Old 02-13-2015, 12:13 PM   #6
When you did the compression test, did you pin the throttle body in the wide open position?
That could account for the low compression readings...
Compression spec test Tork6 1979-1995 Mustang GT 2 04-16-2013 05:02 PM
Compression test Gmkiller 1979-1995 Mustang GT 1 12-26-2012 04:45 AM
Mach 1 compression test? MachMan1017 General Mustang Discussion 1 09-04-2012 10:30 PM
Compression test... Mathew r Wright 1996-2004 Mustang GT 2 03-08-2012 02:40 PM
Mustang Wheels and Tires FAQ: Come here for questions concerning tire size!! Zim Mustang Wheels & Tires 24 12-25-2010 10:55 PM
06:13 PM
