Help with cam drivability - Mustang Evolution
Old 02-12-2015, 04:13 PM   #1
keeney35's Avatar
So I'm getting the stage three comp cam 270 installed this weekend and I won't able to get a tune for maybe another week or 2.. I was told it should run rich down low and lean up high but that there is some throttle screw or something I can adjust to help with that.. Is it gonna hurt anything new to drive it with no tune for just a few weeks? Just city driving to work..
keeney35 is offline   Reply With Quote
Old 02-12-2015, 05:00 PM   #2
DetroitMuscle99's Avatar
It shouldn't just don't be racing around drive it normal. It may idle hunt etc that's why they mentioned throttle screw
DetroitMuscle99 is offline   Reply With Quote
Old 02-12-2015, 05:17 PM   #3
keeney35's Avatar
I figured I'd have to give it a little gas or something at a light
Old 02-12-2015, 05:19 PM   #4
If your getting it installed by a decent mechanic he should be able to get it to hold idle for you no need for all that. I have same cams or similar ones 270in 274 ex .550 lift and ported/polished stage two heads and it wasn't all that bad, I did them myself. I did mess around with the throttle body etc and get it to hold idle but sometimes it would still idle hunt. You are at least upgrading your valve springs right?
Old 02-12-2015, 05:25 PM   #5
keeney35's Avatar
He's doing my long tubes and cam at the same time since he's gonna probably lift the engine and mess around the same area so he's cutting me a deal to install both for 550$ so that's not bad, and my gears are goin in this weekend for 200$
Old 02-12-2015, 05:26 PM   #6
Valve springs.... Are you doing valve spring upgrade? It's required for those spec cams bro. What is the lift on your cams? Give me all specs.
Old 02-12-2015, 05:34 PM   #7
keeney35's Avatar
Yeah I got the beehive springs and new retainers
Old 02-12-2015, 05:35 PM   #8
keeney35's Avatar
http://www.americanmuscle.com/mustan...s-xe270ah.html
Old 02-12-2015, 05:36 PM   #9
Okay your good than
Old 02-14-2015, 06:24 PM   #10
270s are close with the stock valve reliefs, very close. He is going to properly degree them right? He had damn sure better degree them and not try to use the factory marks.
As far as a tune, it will run like **** until its tuned, I would not run it around untuned. You can do just fine with a mail order tune, sometimes as good or better than a dyno tune because a good remote tuner will use your datalogs from the street. When I say good remote tuner, I don't mean bama or steeda btw, I mean someone who actually datalogs like MPT.
Old 02-14-2015, 06:29 PM   #11
270s you will have to degree a crap ton so they don't hit the valves. At that point it's not even worth it
Old 02-14-2015, 06:37 PM   #12
He'd be much MUCH better off going with Cushman Stage 2 NA cams. MUCH.
Old 02-14-2015, 08:45 PM   #13
This^^^^^
drivability of ghost cam tune? r00st 2011-2014 Mustang GT 76 03-01-2018 09:46 AM
mustang drivability issue wss003 1979-1995 Mustang GT 2 11-02-2011 08:14 PM
68 Drivability Issues Shanes0406 Classic Mustangs 6 05-17-2011 07:38 PM
Cam Cores needed for RDMotorsport cam GP RGR Mustang Parts for Sale and Wanted 3 03-05-2005 05:53 AM
08:16 AM
