Cracked injector - Mustang Evolution
Old 02-13-2015, 05:29 PM   #1
Cracked injector
Took my injectors out today to clean. Basically hooked a 9v to it while spraying carb clean. They were pretty grimes and the one test drive so far has been a big improvement, especially third and fourth. I did notice however the end ceramic tip on one injector was cracked all around. Not loose or anything and its probly been like that for a while but Im definately replacing it. Close to stock car so no need for bigger injectors. So should I relace all injectors? What is stock psi, 19? Best brand for money? Thinking motor craft. Is it just the 170000 miles that caused this? Cuz they are original
Calebnc302 is offline   Reply With Quote
Old 02-13-2015, 05:47 PM   #2
Terminator's Avatar
I have some 24# injectors im selling now for $70 shipped if you would be interested havent made a ad for it though
Terminator is offline   Reply With Quote
Old 02-13-2015, 06:02 PM   #3
That part that gets cracked is called a Pintle cap. You can replace it.
There is more to servicing a fuel injector than meets the eye. There is also a small fuel filter inside of the injector that is replaceable.
You can buy the replacement parts at Mrinjector.com.
Old 02-13-2015, 07:42 PM   #4
Can i pay you with gum haha
clinesr22 is offline   Reply With Quote
Old 02-15-2015, 07:55 AM   #5
Just rebuild them and make sure they are clean like you seem to have already.
Old 02-15-2015, 10:30 AM   #6
Yea just ordered a kit with filters orings and caps For like $19
Old 02-15-2015, 02:19 PM   #7
Yep, way cheaper doing it that way and you probably already got them clean with the 9V and the cleaner. You will probably be amazed at how much better the car runs. Changing to rebuilt/new injectors has cured everything from a rough idle and lean/rich issues on former cars I've owned not to mention going from shot injectors to fresh will give you a bit of a power bump depending on how bad the old ones were.
Old 02-15-2015, 03:16 PM   #8
Yea I never thought about injectors until someone on here said to try and clean them. So glad I did, I would recommend everyone doin it
Sent from my iPod touch using Mustang Evolution
Old 02-15-2015, 06:53 PM   #9
Yep, I gots to pull them out of my Expy here when it warms up and get a can of cleaner, a battery and a rebuild kit and go to work.
Old 02-16-2015, 05:53 AM   #10
Is there a thread on a proper way to clean em?
2000 GT 5spd. minor bolt ons
stockxcarx29 is offline   Reply With Quote
Old 02-16-2015, 08:34 AM   #11
They are really simple mechanically so as long as you spray something through them while holding a 9v to it, or maybe a ultrasonic parts cleaner or whatever it's called. And to rebuild them there's some good vids on YouTube
Old 02-20-2015, 03:19 AM   #12
fenixignition's Avatar
Holy crap I wanna try this. Ill let you know when I do and what my results are.
Sent from my GT-P3113 using Mustang Evolution mobile app
2002 GT 5sp. 16x,xxx miles
Old 02-20-2015, 05:29 AM   #13
I usually just rebuild them but if you want to run cleaner through them you rig up a tube with some HEET or whatever to the injector, get a couple blade connectors with leads on them and touch them to a 9V and watch the spray pattern. If it mists nicely then move onto the next one.
Old 02-20-2015, 05:32 AM   #14
even better. i already have new o rings on them all, its just the filter and the other part that's new to me. Am i tapping the 9 volt in pulses for individual sprays? or will touching and holding the connection to the battery cause a constant spray?
Old 02-20-2015, 05:43 AM   #15
Should be constant but whatevs.
Old 02-20-2015, 07:51 AM   #16
Lorraine's driver
ab_mach1's Avatar
Thanks for ^this info.
IG: @azurebluemach
Instagram: @ab_mach1
cracked pi manifold greg_g70 1996-2004 Mustang GT 8 12-10-2004 11:55 AM
This cracked me up! Brent The Bar 4 03-27-2004 08:43 PM
Cracked Trim Piece ericstanley Mustang Audio & Video 3 02-16-2004 04:16 AM
Cracked Head or Head Gasket problem DMustanger Pre-2005 V6 Mustang 21 12-17-2003 06:52 AM
My Damn Windshield is cracked!!!!!!! Danger Dude The Bar 25 11-23-2003 04:59 PM
08:27 AM
