03 GT grinding noise front end - Mustang Evolution
Old 02-16-2015, 06:57 AM   #1
XSlashDashX's Avatar
When turning left or right I can hear like a metal grinding noise from the front end. Only happens when I turn either direction. Driving is fine.
Old 02-16-2015, 12:09 PM   #2
Lift the front wheels off of the ground and check the wheel bearings for any play. And everything else while you are at it! If you can't find anything obviously wrong, remove the front wheels and give everything a thorough inspection.
Old 02-16-2015, 04:34 PM   #3
DetroitMuscle99's Avatar
Sounds like a bad wheel hub assembly or both of them
DetroitMuscle99 is offline   Reply With Quote
Old 02-25-2015, 02:56 PM   #4
Alright, so what I end up doing was replacing both ball joints, inner and outer tie rods. Little over 117K miles and none has been replaced until now. Add a finish touch of a new radio and speakers and done!
ID:	176180   Click image for larger version
ID:	176182   Click image for larger version
ID:	176184   Click image for larger version
ID:	176186   Click image for larger version
Old 02-28-2015, 09:05 PM   #5
thyreaper's Avatar
If its when u turn only ur rim could be rubbing ur lower control arm or ur outer tie rod end ( my gf 97 her rim was rubbing the lower control arm )
thyreaper is offline   Reply With Quote
86 front end into an 89 front end Beatjunkiexorge 2.3 Mustang 1 05-18-2013 07:07 PM
Grinding Noise From Gears parkerr1 General Mustang Discussion 5 12-16-2008 05:34 PM
loud grinding noise! roach 1996-2004 Mustang GT 13 03-24-2008 10:01 AM
grinding noise from pass. front jimmy_beaner 1996-2004 Mustang GT 3 12-17-2006 07:37 AM
grinding noise from diff. Horse Pre-2005 V6 Mustang 8 04-27-2004 04:47 PM
11:57 AM
