Fml - Mustang Evolution
Old 02-16-2015, 10:51 AM   #1
Angry Fml
Recently I bought a new intake manifold for my 1999 gt. While I was taking the old manifold off, somehow a simple flat washer fell in to one of the spark plug holes. The washer is the perfect size to fit around the top of the plug and fit perfectly into the hole with about 1/32" of space all the way around. So now I cannot put my motor back together because the washer stops the coil pack from going on to the plug. I have tried everything I can think of to get the washer out and still no luck. Any ideas or suggestions would be appreciated.
1999 mustang 4.6 gt
Chris629 is offline   Reply With Quote
Old 02-16-2015, 10:55 AM   #2
Noodles76's Avatar
Crack that sucker open.
2014 5.OHHHHHH
Noodles76 is offline   Reply With Quote
Old 02-16-2015, 11:01 AM   #3
Grimkreg's Avatar
magnet stick(I dont know the real name for it lol)?
Grimkreg is offline   Reply With Quote
Old 02-16-2015, 11:02 AM   #4
I tried that, even the smallest one is to big to fit into the space between the plug and the wall.
1999 mustang 4.6 gt
Old 02-16-2015, 11:13 AM   #5
Lorraine's driver
ab_mach1's Avatar
What about long narrow screw drivers used together to work it back up and out? Maybe the washer is kinda wedged in. The screw driver might be able to losen it such that the magnet can snag it..?
Instagram: @ab_mach1
Old 02-16-2015, 12:03 PM   #6
Try using a vacuum cleaner to suck it out. A shop vac will work best but any one should work. Just ring the spark plug hole with some rags to get a good seal and use a suitable attachment on the vacuum cleaner.
Old 02-16-2015, 02:59 PM   #7
08Mustang's Avatar
Now that's creative right there!
08Mustang is offline   Reply With Quote
Old 02-16-2015, 04:31 PM   #8
DetroitMuscle99's Avatar
Go get some thin bendable wire from a hardware store. If you make a hook or get it through the hole you could get it out.
DetroitMuscle99 is offline   Reply With Quote
Old 02-16-2015, 06:10 PM   #9
WJL
Compressed air, it should blow up and out
WJL is offline   Reply With Quote
Great fml. Timm04 Pre-2005 V6 Mustang 11 03-26-2012 12:07 PM
Fire. Fml Brett Greene 1979-1995 Mustang GT 16 09-28-2011 09:51 PM
Got a fricken ticket.... FML GoldenPonyBoy 2005-2010 V6 Mustang 8 08-12-2011 09:55 AM
FML, the V6 is HURT. theACE 2011-2014 Mustang GT 36 02-15-2011 04:09 AM
New jersey state inspection fml 04machazblue General Mustang Discussion 14 02-05-2011 04:45 PM
03:14 PM
