Manual trans 03 gt - Mustang Evolution
Old 02-16-2015, 05:31 PM   #1
Manual trans 03 gt
What kind of fluid do you recommend. I want to change as I'm grinding a bit going into 2 (it is -1 degrees) any thoughts I read mercon NON-synthetic for this year.
snap_on_229 is offline   Reply With Quote
Old 02-16-2015, 05:46 PM   #2
natestang07's Avatar
Penzoil Synchromesh at 3.2 quarts is the reccomendation you will get a lottttt
Old 02-16-2015, 05:56 PM   #3
Thanks!
Old 02-17-2015, 04:37 PM   #4
Update: trans drain was so tight I didn't try to hard to remove didn't want to crack case. Fluid doesn't look to bad nic and red. Shifts fine when warmed up. It's still in the negatives outside temperature wise.
Old 02-18-2015, 06:24 AM   #5
So you're saying you swapped in the pennzoil synchromesh and it shifts better?
Old 02-18-2015, 09:24 AM   #6
No couldn't. Drain plug seized gonna try again today
Old 02-24-2015, 05:24 PM   #7
Drained and filled with pennzoil synchromesh and what a difference. Is recommend it to anyone.
manual trans question andreas 1979-1995 Mustang GT 3 04-26-2007 12:25 PM
manual trans oil 00stang3.8 Pre-2005 V6 Mustang 4 12-28-2006 03:28 PM
Just bought a 2006 V6 Manual trans Pony pkg Rick0636 Pre-2005 V6 Mustang 17 02-22-2006 08:18 AM
2006 V6 Manual Trans - Bucks in 1st Gear in AM lovcom Pre-2005 V6 Mustang 9 11-20-2005 09:08 AM
05 v6 manual trans.. MonteCitan Pre-2005 V6 Mustang 29 01-07-2005 04:40 PM
05:38 AM
