1997 Mustang GT - Mustang Evolution
Old 02-16-2015, 08:57 PM   #1
1997 Mustang GT
Hey guys, I have owned my 97 GT for over a year now and I've always wondered what the noise was coming from the rear end of the car when I turned the key into the "on" position. However, yesterday my car was running fine when I took my friend to run an errand. Before I left home, my car would not start, and that whining noise was not produced either. I have come to consensus that the whining noise was the fuel pump. Could it be possible that the fuel pump would go out on a simple drive? Or could it be something else? Any help is appreciated, thanks!
Raymennnn is offline   Reply With Quote
Old 02-16-2015, 10:47 PM   #2
XSlashDashX's Avatar
Its the fuel pump you hear. If you don't hear it then its probably out.
Old 02-17-2015, 02:45 PM   #3
Site Sponsor
Sponsor
AMWill's Avatar
Hey Raymen,
The whine you hear from the rear is indeed the fuel pump.
If you have been hearing the whine more and more and then all of a sudden it goes out along with the car, you most likely lost your fuel pump which is not uncommon at all! The car is almost 20 years old after all.
Luckily, it should be an easy fix which is as simple as swapping the fuel pump.
I would definitely recommend having this diagnosed at a shop just in-case but I am fairly confident that you simply need to replace your fuel pump.
Hope this helps and let me know if you have any questions!
-Will
Toll Free: 866.727.1266
Free Same-Day Shipping!
Old 02-17-2015, 04:37 PM   #4
Lorraine's driver
ab_mach1's Avatar
There should be a fuel pump relay too. You should check that first before heading straight for replacing the pump. The one in my 88 GT went out and it was a cheap fix I could do easily myself.
IG: @azurebluemach
Instagram: @ab_mach1
Old 02-17-2015, 05:42 PM   #5
Is the fuel pump inside the tank or somewhere else??
Old 02-17-2015, 06:00 PM   #6
The_Chech's Avatar
The fuel pump is inside the tank. Its rather easy to get to these and replace if situation dictates. I my self had a code for low fuel pressure at the fuel lines today. So now I get to try and figure out why in this wonderful weather we are having lol.
Oxford White Roush Stage 1 SN# 6925--SOLD but never forgotten!
Kona Blue GT premium - Slammed on BC's and BMR's full rear suspension
The_Chech is offline   Reply With Quote
Old 02-17-2015, 07:42 PM   #7
1997 Mustang GT
Alright guys thanks for the help! I'll give you all, feedback and see if this was my problem
Old 02-18-2015, 09:48 AM   #8
2011BlackGT's Avatar
Its definitely the fuel pump. I could always here mine whining on my 2000 GT. They can go out at any time.
Black 2011 GT Brembo Brake Package
2011BlackGT is offline   Reply With Quote
Old 02-19-2015, 11:53 AM   #9
3.21gwGT's Avatar
I also have a 97 mustang gt and mine also whines like crazy
3.21gwGT is offline   Reply With Quote
Old 02-19-2015, 04:33 PM   #10
1997 Mustang GT
So now that I changed the fuel pump (this was the problem as to why my car didn't start), the whining noise went away. It isn't as dramatic
Old 02-21-2015, 04:27 PM   #11
3.21gwGT's Avatar
How hard was it to drop the tank and replace the pump ?
Old 02-21-2015, 06:00 PM   #12
Well the hardest part was to drop the tank. It was half way full... When it was off the car, we siphoned the gas as much as we could. Replacing the fuel pump was the easiest part. Took about 3-4 hours within two days because of short daylight hours.
1997 mustang
Ford Mustang :: 1997 Ford Mustang P2Racing Member Garages 0 07-02-2012 08:21 AM
is the power steering pump from a 1997 Lincoln mark viii the same as the 1997 cobra Cobra209 SVT Mustang 2 05-04-2012 01:40 PM
Will a Manual tranny off of a 5.0 Mustang Fit my 1997 Mustang GT (v8)? BrKu789 1996-2004 Mustang GT 1 08-03-2011 04:35 AM
07:49 PM
