MAF Sensor Question - Mustang Evolution
Old 02-19-2015, 08:55 AM   #1
TheLastDraggin's Avatar
MAF Sensor Question
I have searched the forum to no avail regarding this question. So here goes. I have been reading/researching about mass air flow sensors and how to tell if they are bad. There have been several bits of info that say you can unplug the maf and the engine should die, and if it doesn't, you have a bad sensor. Is this true with my 98 'vert?
Sent from my SPH-L600 using Mustang Evolution mobile app
TheLastDraggin is offline   Reply With Quote
Old 02-19-2015, 10:32 AM   #2
A faulty MAF will typically trigger a trouble code but not always. If you haven't checked for any pending codes, you may want to do so, as there can be a code with no CEL.
A basic test for the MAF is to disconnect it with the engine turned off and then start the engine. If the MAF is faulty, it will typically run better with the MAF disconnected because the PCM can do a better job when it is not receiving incorrect air flow information.
Old 02-19-2015, 01:20 PM   #3
Understood. Thank you for your response. I'll do just that!
95 5.0 MAF upgrade to a 80mm 2000 4.6 MAF chatanaka36 1979-1995 Mustang GT 3 07-03-2012 08:57 PM
maf sensor question workmail21 1979-1995 Mustang GT 6 06-16-2011 04:38 PM
MAF Sensor?? Rocket50 1979-1995 Mustang GT 2 12-23-2006 09:36 AM
Cobra MAF sensor, WTB WhiteStang99 Mustang Parts for Sale and Wanted 2 11-22-2005 08:51 PM
Maf Sensor Torx Bit Screws sctalbott Pre-2005 V6 Mustang 5 01-12-2004 01:51 PM
04:38 AM
