Steering creak - Mustang Evolution
Old 02-19-2015, 06:56 PM   #1
Polar Bear's Avatar
Region: Asia
Steering creak
97 GT started creaking when turning right. Ordered the Steeda Ball Joints and Bumpsteet kits. Figured it's a good time to upgrade. What else should I look at changing while the steering is pulled apart?
Steve
Polar Bear is offline   Reply With Quote
Old 02-19-2015, 07:05 PM   #2
Check everything! Replace anything that is worn out or looks suspect. And order a new set of bushings for the steering rack... That is a likely source for creaking.
I rebuilt the entire front end on my car and it drives like new.
What did you end up doing to repair your charging system issue?
Old 02-19-2015, 07:14 PM   #3
Polar Bear's Avatar
Region: Asia
AM supplied a replacement alternator. I replaced the power wire as well. Still having the issue but not as bad. Has to be ground but no idea where.
Steve
Old 04-21-2015, 07:58 AM   #4
Polar Bear's Avatar
Region: Asia
Ordered the Steeda Ball Joints and Outer Tie Rods along with the various bushings. Don't have a press for the ball joints so took the car to a shop to have the replacements done. They got the car lifted and the passenger side Eibach spring was broken in two separate places. They called me to the shop to show me the spring. That was my noise problem. Now I have to order springs before doing anything more.
Steve
Old 04-21-2015, 08:50 AM   #5
Steve96's Avatar
Wow that sucks. How long have you had the eibachs?
1996 GT
Old 04-21-2015, 08:54 AM   #6
I'd send the pics to Eibach and see what they will do for you. They SHOULD refund you the money or send you new springs.
Old 04-21-2015, 12:20 PM   #7
Lorraine's driver
ab_mach1's Avatar
That should never happen lol...unless you heated them up to get moar low
@azurebluemach
Instagram: @ab_mach1
Old 04-21-2015, 03:45 PM   #8
Polar Bear's Avatar
Region: Asia
The Eibachs were on the car when I bought it 3 years ago. That being said I don't know how long they were there. One of the few mods done to the vehicle at that time. I've put Koni stunts/shocks in but nothing else suspension.
Steve
Brake creak issue. Jvibe92 2011-2014 Mustang GT 4 06-02-2015 06:45 PM
Creak noise when turning the wheel sebasflorez Pre-2005 V6 Mustang 19 11-21-2013 01:20 PM
Embarrasing Steering Creak? ccabral14 1996-2004 Mustang GT 20 11-16-2013 10:22 PM
Floor Mats and Dash Creak Jeffola 2011-2014 Mustang GT 13 01-13-2012 08:25 AM
Can you interchange a 1965 mustang steering wheel with a 1967 steering wheel? gruffudd91 Classic Mustangs 1 08-26-2009 04:38 PM
03:23 AM
