Car cranks and cranks then starts weak - Mustang Evolution
Old 02-20-2015, 04:50 AM   #1
Anth0nyxGT00's Avatar
Cranks and cranks and the starts really weak like putting sound knocking and rocking also turning key and some times nuthin happens I have to put it in neutral to start could be neutral safety switch but Idk also idle is dropping to 0 car stalls out its an auto trans the idle drop is new tho brand new iac valve new battery starter is good crank shaft position sensor replaced also thinking of the pcm fuse no check engine light is on tho
Anth0nyxGT00 is offline   Reply With Quote
Old 02-20-2015, 08:19 PM   #2
Even though there is no CEL, there may still be a pending code.
I would start the diagnosis by doing a fuel pressure test.
Old 02-21-2015, 12:01 PM   #3
surfinglbi23's Avatar
Is the IAC from Ford? The autozone ones and similar are known as problematic. I'd check that for sure.
surfinglbi23 is offline   Reply With Quote
Old 02-21-2015, 12:18 PM   #4
Panther140's Avatar
You say it makes a knocking sound? Like rod knock? and sometimes turning the key doesn't do anything? like its seized up? and when it does start its reluctant to run at all?
Check your oil for metal flake/shrapnel. It sounds to me like you seized the engine and now it sometimes will run a little bit. I could be wrong though. SOunds exactly like the first time I blew up a car engine.
Panther140 is offline   Reply With Quote
Old 02-21-2015, 01:47 PM   #5
Naw the engine is not blow it runs and drives no metal In the oil just upon start up its very weak
Old 02-21-2015, 01:51 PM   #6
Could be the starter starting to go...
Adventure till you drop
Old 02-21-2015, 02:50 PM   #7
gqsmash's Avatar
Have you changed your fuel filter lately? I know I've seen some cars spit and sputter on start up and then drive normal after pressure is built up
gqsmash is offline   Reply With Quote
2003 Mach 1 Starts Then Stalls 5 Seconds Later TweakFreak 1996-2004 Mustang GT 2 06-02-2014 08:56 AM
Blinking Cel and then stopped blinking on my 2012 mustang gt with less then 400 miles sleeperstatus 2011-2014 Mustang GT 5 05-03-2012 06:16 PM
Starts...then, won't start shustwit Pre-2005 V6 Mustang 8 09-20-2011 05:23 AM
Hunt for a mustang starts in less then 2 weeks!!! sonic04edge The Bar 4 06-15-2010 10:13 PM
weak braking greenpony02 Pre-2005 V6 Mustang 9 08-08-2005 06:04 PM
06:41 AM
