Swapping mid-pipe - Mustang Evolution
Old 02-22-2015, 01:59 AM   #1
joe_117's Avatar
Swapping mid-pipe
Anything I need to know before I swap my stock mid-pipe?
joe_117 is offline   Reply With Quote
Old 02-22-2015, 02:11 AM   #2
The passenger side bolts suck.
Old 02-22-2015, 02:23 AM   #3
joe_117's Avatar
Can I re use the bolts to bolt up my x pipe?
Old 02-22-2015, 02:24 AM   #4
joe_117's Avatar
Unfortunately it doesn't come with bolts and clamps. So I'm gonna either have to weld, or find a place that Sells them.
Old 02-22-2015, 07:08 AM   #5
The_Chech's Avatar
I had to take my starter off on the passenger side to get it unbolted from the headers.
Oxford White Roush Stage 1 SN# 6925--SOLD but never forgotten!
Kona Blue GT premium - Slammed on BC's and BMR's full rear suspension
The_Chech is offline   Reply With Quote
Old 02-22-2015, 09:00 AM   #6
joe_117's Avatar
Really?
Old 02-22-2015, 12:22 PM   #7
It does help to get in there and the starter pretty much falls right out. Bolts are easy to get at, even the top one that ppl gripe about. You just go in from in front of the K member with like 2ft worth of extensions and a swivel and take it out/re-install it that way. You also do not have to put the top starter bolt back in if you don't want to, most ppl don't and there are no issues.
With that said, you don't need to remove the starter but you will need a 1/2" ratchet set to do the passenger side at the collector. 3/8" deepwells are too big to fit in the space there and 3/8" shallows aren't deep enough. 1/2" shallow sockets are deep enough to just get on but not deep enough to not fit... If that doesn't make sense, it will when you get under there and look at it. I LOATHE shorty collectors and how the mid pipes work personally... longtube mid pipes are so easy its ridiculous but this isn't exactly something you need to do very often either. Oh... make sure you get a new gasket for the pass side collector. Its like $6 at autozone. Driver's side does not use one.
Old 02-22-2015, 01:29 PM   #8
natestang07's Avatar
I tried to message this to you but you can't message pictures. New rim selection for your expy
Old 02-22-2015, 01:31 PM   #9
You can if you don't strip them... I meant they suck as in they suck to take off. Not a lot of room, the cats are in the way, and they are on there really really good.
Old 02-22-2015, 01:33 PM   #10
My midpipe is welded together because they couldn't keep it from leaking
Old 02-22-2015, 01:35 PM   #11
Yea i don't like the bolt design. Its good for if you need to ever take the exhaust off. But its a pain to not leak. My Mac H pipe is in 3 pieces. The H part and then head of the up pipes leading to the headers is its own. So i can attack those first to make sure its nice and snug to the headers then deal with the H part.
Old 02-22-2015, 02:51 PM   #12
Lol I just have stockers with good AT-S tires. There are some GHETTO *** older expy and navis out there now that they are cheap to get.
Old 02-22-2015, 03:43 PM   #13
Gasp I see Scotty's reflection!!!
Old 02-22-2015, 04:42 PM   #14
joe_117's Avatar
So pretty much a new gasket, other than that it's all self explanatory? I just don't wanna have to go to a shop and them do it. They can weld it but if they do it will cost labor and they keep your cats...
Old 02-23-2015, 07:11 AM   #15
Do NOT weld the mid pipe to the headers, that is just asinine. Install the gasket properly on the right and tighten up the bolts on the left evenly. Start it up while its still on ramps and let the exhaust heat up, then turn it off and carefully get back under and re-tighten. After 3 or 4 more heat cycles, re-tigthen again and then maybe one more time a week later. Sucks but exhaust bolts love to loosen up. Why I love longtubes with V bands honestly. It should all be V-bands IMO.
Old 02-24-2015, 11:58 AM   #16
Panther140's Avatar
if you don't have one of these:
You should go out and get one of them.
Panther140 is offline   Reply With Quote
Old 02-24-2015, 12:34 PM   #17
joe_117's Avatar
Can you re use stock bolts?? Curious, and I ordered clamps, and a gasket for the rh side!
Old 02-24-2015, 01:52 PM   #18
If they aren't too corroded then yeah you should be able to re-use stockers.
Old 02-24-2015, 07:51 PM   #19
joe_117's Avatar
Can you send me a link where they sell em? I don't want know trouble with this mid pipe when I'm doing it.
Old 02-25-2015, 07:08 AM   #20
You can get them at your ford dealer, look up "ford parts network" on google and its pretty intuitive.
LRS may sell them too, not sure.
H pipe vs x pipe vs straight pipe 509pony 2005-2010 Mustang GT 100 02-15-2015 08:35 AM
Mid pipe with mid mufflers? Tompkins 2005-2010 Mustang GT 5 03-27-2010 12:26 PM
Long tube mid pipe Ninethourpm Pre-2005 V6 Mustang 25 03-18-2010 09:41 PM
Getting new catback/headers, need mid pipe? CreationNation 1979-1995 Mustang GT 13 03-31-2009 07:57 AM
I want a new mid pipe 01mineralgrey6 1996-2004 Mustang GT 17 05-25-2005 09:16 PM
05:10 AM
