How to adjust gear ratio in sct tuner? - Mustang Evolution
Old 02-22-2015, 02:21 AM   #1
GHO5T5NIPER's Avatar
Hey guys my car is In the shop right now getting 4.10s installed and I left my bama tuner in it so I can't get the code off of it to have a new tune rewritten. I've heard of people somehow changing the rear end gear themselves through the tuner but how exactly do u do it and does it work perfectly fine? Thanks
GHO5T5NIPER is offline   Reply With Quote
Old 02-22-2015, 06:51 AM   #2
Black8thElement's Avatar
I would reach out to bama asap. I could be wrong but you would have to return your car back to stock before uploading a new tune.
Then use a strategy tune and select 4.10 gears. But many don't suggest using them because its a generic tune.
But easily call Sct or Bama they get paid to help people let them help hahaha
Sent from my LG-E980 using Mustang Evolution mobile app
Black8thElement is offline   Reply With Quote
Old 02-22-2015, 06:57 AM   #3
DetroitMuscle99's Avatar
Before you load the tune there is a edit tune options. Click on it then scroll down to gear setup and put in your new gear ratio. I Also use the rev limit option from the tune option list. I use the neutral rev limiter as a two step and set my rev limit at 6,100rpm for when I spray. Window switch is set at 6,000rpm.
This is why we play the game... to separate the contenders from the pretenders!
DetroitMuscle99 is offline   Reply With Quote
Old 02-22-2015, 01:45 PM   #4
Ok thank you very much! Does it fix the speedometer perfectly? I tried to mess with the revs/mile when I put bigger tires on it and the speedometer wasn't even close
Old 02-22-2015, 01:46 PM   #5
It's easy to do. Strategy tune section and it gives a bunch of options to select which gears.
Old 02-22-2015, 02:18 PM   #6
I've had the same gears for while now and only used a bama tune once then took it to a local shop for tunes from then on out. It matches my speedo pretty spot on. I wouldn't be using it if otherwise. If you have different wheel/tires, gears etc than of what they originally tuned for than put it in on the options list but I would have them send a new free tune just to be sure everything matches up and is as good as it can be. Probly will not match up perfect until the initial tune is for your gear set.
Old 02-23-2015, 08:01 AM   #7
Site Sponsor
Hey GHO5T5NIPER
That's a really great question and if you're making the swap I would really reccomnend shooting the Bama Team a call and have them shoot over a revision so that once the rear is buttoned up you're going to hit the ground running! Shoot them a call at 888.226.9764 and they'll get you set up today!
Let me know if you have any other questions in the meantime and I'm here to help!
Alex
Toll Free: 1-866-363-4591
Free Same-Day Shipping!
Old 02-23-2015, 09:23 AM   #8
Originally Posted by AMAlexLazarus View Post
Hey GHO5T5NIPER
Alex
Can they do it without the number on the back if the tuner? I have all the other information but like I said I left the tuner in the glove box and I'm sure he already has it in the air lol
Things To Adjust With Tuner BlackSmoke02 Pre-2005 V6 Mustang 1 01-15-2014 04:00 PM
Gear or Sct tuner Siendly22 General Mustang Discussion 2 12-23-2011 01:05 AM
Tranny gone did use the 2.3 trans on my v8 n likd the gear ratio but now wat to do? Justbust1n 1979-1995 Mustang GT 18 02-26-2011 08:07 PM
Rear Gear Ratio natestang22 Pre-2005 V6 Mustang 2 07-20-2007 11:31 AM
1996 Mustang GT rear end gear ratio Buzz 1996-2004 Mustang GT 2 04-23-2006 07:19 PM
03:09 PM
