Swap - Mustang Evolution
Old 02-22-2015, 10:39 AM   #1
Zinc's Avatar
Swap
I finally have a coyote engine and was wondering what else do I need I have a 3.8 mustang 2002 and I also have a 8.8 resr suspension. What else is needed
Zinc is offline   Reply With Quote
Old 02-22-2015, 12:16 PM   #2
-Control Harness -$1500
-Adapter accessories - $700
-Swap headers/mid pipe -$1100
-Transmission -$1500-$4000 depending on what you get
-Fuel system -$1000
-3" catback -$500
-Tune $500
-Misc other stuff $500-$1000
-$250-$500 for intake/exhaust cams depending on which version of the Coyote you got and if you want to upgrade to GT/Boss spec.
I'm sure I'm forgetting some stuff, there are comprehensive lists out there if you google around.
Hopefully you didn't pay more than $2500 for the Coyote motor from a pick and pull/JY since that's what the F150 Coyote goes for and its damn near identical.
That's just to get it running and doing it yourself. Factor in a lot more if you are having a shop do it.
You'll also want to upgrade the brakes, suspension, rear gears and reinforce the chassis. Since you are a V6 you are going to need to source V8 accessories too.
I am not trying to be a killjoy but I say this to many ppl looking to do this swap, actually research and tally up EVERYTHING plus the cost of the car (and what you think your time is worth) and see where you are at. You can buy a real low mileage Coyote for $20k and a higher mileage one (like 60-80k miles) in good shape for $17k. It may be something you want to consider before moving forward.
To Swap, or not to swap...... Strongarm 1979-1995 Mustang GT 5 02-05-2008 01:39 PM
09:28 PM
