04 gt Starting problems - Mustang Evolution
Old 02-22-2015, 05:40 PM   #1
I have a 04 mustang gt and here recently it has started having problems starting when it gets cold. The fuel pump wouldn't turn on once it gets cold I couldn't hear it prime so I thought the fuel pump was out. We'll I replaced the fuel pump with a walbro and everything was fine I thought until it got cold again. Now with the new fuel pump I have the same symptoms as when I had the old one in. Plus now I'm getting a dtc p1235 fuel pump out of range. Plus the car runs rough sometimes and sometimes it's fine. Could I have a bad fpdm. Any help would be appreciated.
Sent from my SAMSUNG-SM-N910A using Mustang Evolution mobile app
gt210 is offline   Reply With Quote
Old 02-22-2015, 06:24 PM   #2
Mfore33's Avatar
Maybe a bad emergency cut off switch in trunk
Old 02-22-2015, 06:48 PM   #3
I checked the inertia switch and it was fine I even pushed it to make sure it wasn't popped out. I was thinking the fpdm maybe or ccrm but I read the ccrm rarely goes out.
Old 02-23-2015, 02:14 PM   #4
Bump
Old 02-23-2015, 04:02 PM   #5
The FPDM would be the next thing to check.
Since you say that this generally occurs when it is cold, you should inspect the wires and the connector, to the FPDM, for any damage or corrosion that could be affecting the electronics when it is cold and damp.
Old 02-24-2015, 08:44 PM   #6
Okay I will do the test for fpdm this weekend and get back with the results
Old 02-26-2015, 06:02 PM   #7
Panther140's Avatar
Fuel pump relay could be the culprit but who knows. I threw that EFI nonsense out the window a while ago (well, the parts are all in my trunk anways)
Panther140 is offline   Reply With Quote
Old 03-15-2015, 05:53 AM   #8
Okay guys well the fpdm is good I replaced it to just make sure and still have the same problem
Old 03-15-2015, 05:54 AM   #9
But i hear a constant humming from the trunk and it seems like a power loss cause you can hear it slow down the pick and that is when the cars idle fluctuates
New owner, 2002 Mustang starting problems skelaw Pre-2005 V6 Mustang 6 02-22-2011 06:57 PM
Starting problems! 99 SVT Cobra 1996-2004 Mustang GT 2 01-10-2010 04:47 PM
1989 5.0 starting problems tellico40 1979-1995 Mustang GT 5 10-19-2006 05:21 PM
Starting Problems Zak Attack 1979-1995 Mustang GT 16 05-17-2006 07:54 PM
1998 Ford Mustang Starting Problems redv6stang Pre-2005 V6 Mustang 4 09-25-2005 02:17 PM
05:27 AM
