HVAC Controls not working - Mustang Evolution
Old 02-23-2015, 11:58 AM   #1
Ponybri's Avatar
My HVAC control, the low to high fan isnt working correctly. The first two options will not blow any air until turned to third option. Need help!!
Ponybri is offline   Reply With Quote
Old 02-23-2015, 01:36 PM   #2
Slater2111's Avatar
Blower motor resistor is out.
Sent from the mothership.
Slater2111 is offline   Reply With Quote
Old 02-23-2015, 03:06 PM   #3
Ponybri's Avatar
Slater2111 thank you! Definitely will check that out today!!
Sent from my SM-G900P using Mustang Evolution mobile app
Old 02-23-2015, 07:46 PM   #4
racks2relax's Avatar
Thanks slater, fixed my problem today on my 90 as well
Sent from my SM-N900P using Mustang Evolution mobile app
racks2relax is offline   Reply With Quote
Old 02-23-2015, 07:59 PM   #5
Slater2111's Avatar
I had the problem on my Honda of all things. Everything I googled pointed to it. Hundreds of people having the same problem and Only one culprit. Blower motor resistor. The resistor has multiple resistances and controls how much power the motor gets for the blower. If they go out no resistance. Hence why it only works on the highest setting.
Old 02-23-2015, 09:22 PM   #6
Ponybri's Avatar
Thanks soo much slater2111, my problem was fixed!!
Old 02-24-2015, 07:34 AM   #7
fenixignition's Avatar
yep to the above.
generally, if its the fan control thats not working, or only certain fan levels work, then its probably the resistor. fan flat out not working, possibly the resistor, but likely the fan motor or the connection. (Easy way to check is to pull it and hook up a 12v source to the fan and see if it runs.)
if its blowing normal but warm and ac is on max, check your ac clutch. if its engaging and disengaging, then a common issue is a freon leak. could still be something else wrong, such as a clog, bad sensors, or even a bad clutch. and be careful about carelessly adding freon. Best to do some research on it. Some people add freon and it fixes everything in their life, and some say dont even touch your a/c without a hvac certification. :/
oh and forgot to add, if the ac clutch wont engage at all, then its either not enough freon to start it up, ac relay, bad compressor, bad clutch, or other. so be careful not to assume its just not enough freon, and then you overload it.
just thought i'd add some more ac related stuff in case it might help someone else looking here.
2002 GT 5sp. 16x,xxx miles
Old 03-01-2015, 12:20 PM   #8
Ponybri's Avatar
Thank you so much fenixignition, i appreciate your time an help!!
How to : LED Cluster / HVAC Controls infamous281 1996-2004 Mustang GT 1 08-19-2012 03:13 PM
A\C working then not working Bohogin Pre-2005 V6 Mustang 3 07-14-2011 01:44 PM
HVAC Controls move tjvaughn Pre-2005 V6 Mustang 0 07-09-2011 09:35 PM
HVAC fan control issue jimmy_beaner 1996-2004 Mustang GT 1 01-24-2009 11:20 AM
Replacing lights in the HVAC controls.. MonteCitan Pre-2005 V6 Mustang 3 09-27-2004 09:08 PM
10:42 AM
