Exhaust manifold studs - Mustang Evolution
Old 02-23-2015, 11:25 PM   #1
Panther140's Avatar
Mine are EFFED. Stripped out bad on one side because I got impatient roid rage with my impact one day. I had to get the exhaust on before my dad got home and tore me a new A-hole for having my manly car in his pristine yuppy garage, and I wound up messing up my exhaust manifold studs that I bolt the H pipe onto.
So.. I am thinking I could make some sort of flange that just mounts behind the current exhaust manifold flange/stud area and also get a new flange that mounts behind the H pipe flange and just presses the pipe onto the manifold without even using the stock studs. Are there any products that can achieve this?
New manifold is out of the question.
Panther140 is offline   Reply With Quote
Old 02-23-2015, 11:28 PM   #2
Panther140's Avatar
FLame suit on
Preparing to be ridiculed for impatient impact action
Old 02-24-2015, 01:12 AM   #3
behemoth's Avatar
Region: Oregon
Are you talking like the studs on the exhaust manifold you connect the x or h pipe too?
Sent from my SM-N910T using Mustang Evolution mobile app
behemoth is offline   Reply With Quote
Old 02-24-2015, 01:15 AM   #4
behemoth's Avatar
Region: Oregon
I had this issue today as well. My friend suggested vice grips or putting 2 nuts on and un screwing it from the first nut.
Old 02-24-2015, 01:16 AM   #5
behemoth's Avatar
Region: Oregon
They do make stud removal kits that pricy but I'm in the same boat
Old 02-24-2015, 03:58 AM   #6
Slater2111's Avatar
I suggest you put down tools and never touch another car. They make excellent bicycles these days that require almost no maintenance.
Sent from the mothership.
Slater2111 is offline   Reply With Quote
Old 02-24-2015, 03:58 AM   #7
Speed_Mister's Avatar
Region: Arkansas
Try using a smaller size socket and tap it on. Preferably a 12 tooth socket.
2004 Mustang GT 5 Speed Full Bolt On 360rwhp 440rwtq
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 02-24-2015, 11:32 AM   #8
Panther140's Avatar
I found these things: I am just going to put these on there: http://image.made-in-china.com/2f0j0...lit-Flange.jpg
Old 02-24-2015, 11:34 AM   #9
Panther140's Avatar
Yeah because everybody knows that if you get impatient and cross thread 1 nut in your life, then you are a terrible mechanic. Lol.
The **** was rusty and I was rushing through it as well as being in a bad mood from the start of the project. So yeah it was one of those times when im twice as likely fo EFF it up.
Old 02-24-2015, 11:35 AM   #10
behemoth's Avatar
Region: Oregon
Won't you still have to remove stud I'm confused
Old 02-24-2015, 11:39 AM   #11
Panther140's Avatar
No, the stud is stripped. IM going to just bypass the whole stock stud/flange and bolt my own flanges onto the pipe&manifold using 100% brand new flanges, bolts, and nuts.
Old 02-24-2015, 11:45 AM   #12
behemoth's Avatar
Region: Oregon
Hmm I bought a replacement stud from ford removed old one by double nut and liquid wrench I was thinking about all new studs but didn't risk snapping and dealing with this again
Old 02-24-2015, 11:52 AM   #13
Panther140's Avatar
Yeah that would work too but it would be a huge pain trying to get the stud out of the rust. I also don't have much threading on the stud
Old 02-24-2015, 11:58 AM   #14
behemoth's Avatar
Region: Oregon
Have you checked local autopartz store to rent stud puller there spose to work even if thread is striped
Old 02-24-2015, 12:17 PM   #15
If you have access to a tap and die set, you can either try to clean up the existing threads and use a brand new nut, or, possibly, cut some new threads that are a slightly smaller diameter.
I have this same problem with the catalytic converter on my trucks. Some of the studs look almost completely smooth but once I get the nut started, and down to the spot on the stud where it has been for the last 25 years, it grabs, and can be tightened down.
exhaust
Broken rocker studs Dadsgl67 Classic Mustangs 48 08-28-2012 12:23 PM
studs for the engine robvandam 1996-2004 Mustang GT 7 04-26-2012 10:53 PM
ARP Main Studs Horse Pre-2005 V6 Mustang 6 06-20-2008 10:11 AM
ARP Head Studs + Headers = :mad: Kiljosh Pre-2005 V6 Mustang 2 02-15-2006 01:46 PM
02:15 AM
