Engine Cant Turn Over - Mustang Evolution
Old 02-24-2015, 07:18 AM   #1
I cant get my 96 Cobra to turn over.
New battery installed. It feels like one of the components pulleyed on serpentine belt is seized up preventing the engine to turn over fast enough to start.
Originally thought it was the starter, then fuel pump. Strange sound and reaction when I turn the key, I've never heard or have seen anything like it.
-I guess I will remove belt and spin each bearing.
Do you agree with loosing belt to spin each pulley?
Would a bad starter behave same way, where engine struggles to spin?
Any help appreciated.
Old 02-24-2015, 07:42 AM   #2
fenixignition's Avatar
i would try to start it up with the belt off just to see if it starts up. but defenitely check your pulleys. i would imagine that it would still start and just rub the belt against the stuck pulley but maybe not, thats still a bit of resistance. could have a mechanical failure in the alternator or the water pump, where a broken piece is causing it to stick and make a noise. but what kind of noise is it?
2002 GT 5sp. 16x,xxx miles
Old 02-24-2015, 11:29 AM   #3
Panther140's Avatar
Dude my starter cranks my car hard enough to start it even if its in gear.. I hope it is just something to do with your serpentine belt but Idk. It doesn't seem quite as promising as id hope
Panther140 is offline   Reply With Quote
Old 02-24-2015, 12:32 PM   #4
Are your battery cables in good condition?
Before you replace anything, check all of the connections and make sure that they are all clean and tight. Pay particular attention to the ground cables. A bad ground is a common cause of this sort of problem.
Old 02-24-2015, 01:01 PM   #5
also check the wire leading to your crank sensor. i was told that a bad or disconnected crank sensor will lead to no start. I think theres a coolant sensor that can cause the same issue.
Old 02-24-2015, 05:26 PM   #6
I had a ranger come in to the shop, monro said it needed a motor because it was locked up. It turned out to be an alternator!
snap_on_229 is offline   Reply With Quote
Old 02-24-2015, 05:31 PM   #7
fwalck's Avatar
I've seen a locked up a/c compressor keep a motor from turning over I would try to start it with the belt off
fwalck is offline   Reply With Quote
Old 02-25-2015, 01:01 PM   #8
Thank You,
I did just replace the alternator a few months ago but have only put a couple hundred miles on it afterwards.
My recollection was that i had upgraded the positive cable but had issues with how to properly ground it.
I'm going to go back out and look over the connections
Thank You All
Old 03-12-2015, 06:44 PM   #9
RESOLVED! Finally!!
The Cobra is back on the streets. What i found was a blown 40 amp ignition module fuse. I also wired in a ground wire to the alternator while the hood was up.
Thanks Everybody!!!!!
Old 03-12-2015, 06:58 PM   #10
The green Mustang above got totaled v2 nights ago. Girlfriend is OK, car is not. Insurance adjuster out tomorrow.
Old 03-12-2015, 07:02 PM   #11
DetroitMuscle99's Avatar
Damn that sucks man
This is why we play the game... to separate the contenders from the pretenders!
DetroitMuscle99 is offline   Reply With Quote
Old 03-12-2015, 07:57 PM   #12
I took it for a little drive secretly
Runs like a beast, handles and brakes fine, steering is tight.
We'll have it looked over tomorrow.
Looked underneath, barely a scrape mark on headers, mid pipe, evt..
-cobra is running great
Old 03-13-2015, 04:57 AM   #13
Oh god, at first i thought you meant the cobra that you just got back on the street got totaled. that would have been awful luck. still bad enough that any of your cars get destroyed, but man, could you imagine the irony?
Old 03-14-2015, 10:29 AM   #14
YEP, Crazy thought!!
The green car still has 10-20 thousand dollars in it.
-Dropped it off at body shop yesterday. With any luck they will fix entire car including dents my wife puts on it daily.
The Cobra is running GREAT!
Thanks
Old 03-15-2015, 09:40 AM   #15
Correction- The Cobra had a 14 amp ignition module fuse blown, not a 40 amp. I replaced it with a 12 amp temporarily until im sure all is good.
I also used a Dremel to clean every positive and negative wire, connector, nuts, and bolts.
Engine Turn Over But No Fire 67 289 Joshy Classic Mustangs 20 01-07-2014 09:01 PM
How to Mute Kenwood Nav Voice Prompts / Turn-by-turn Guidance EastTNMustang Mustang Audio & Video 0 11-03-2013 04:25 PM
Over 100 posts and still cant post on classifieds Jrsgrabber50 ME Site Help & Announcements 3 12-25-2012 12:02 PM
engine wont turn over, help!! fast64 1979-1995 Mustang GT 9 03-21-2005 02:32 PM
07:47 AM
