Wheel bearing/hub bolt size - Mustang Evolution
Old 02-24-2015, 09:36 AM   #1
robin_gt's Avatar
What is the socket size for the bolt that holds the wheel bearing? Thanks in advance.
robin_gt is offline   Reply With Quote
Old 02-24-2015, 12:54 PM   #2
The spindle nut is 36 mm and it must be replaced with a new one. They can NOT be reused!
The nut needs to be torqued to about 250 ft/lbs, which is much higher than a typical torque wrench is capable of, so plan accordingly.
Old 02-24-2015, 12:58 PM   #3
robin_gt's Avatar
Ok thanks!
Quick question about replacing front wheel bearing and hub Mfore33 Mustang DIY and Technical 4 09-26-2014 03:54 PM
Wheel bearing hub MasonStacks 2005-2010 Mustang GT 5 06-08-2014 05:09 AM
Replace wheel bearing/hub? FORDuhl6 2011-2014 Mustang GT 10 02-17-2013 01:02 PM
Pinion Bearing or Wheel Bearing? SCCofSV 2005-2010 V6 Mustang 0 09-30-2012 02:43 PM
Hub/wheel bearing 02PONY 2005-2010 Mustang GT 6 04-09-2012 12:51 PM
02:33 PM
