Coolant coming out of the overflow tank - Mustang Evolution
Old 02-24-2015, 05:27 PM   #1
Rich04's Avatar
Changed the thermostat and radiator hoses, stopped for a little now it's back. Only comes out on WOT someone suggested changing the overflow tank. Any advice ?
Rich04 is offline   Reply With Quote
Old 02-24-2015, 05:36 PM   #2
Well just don't drive at WOT and this won't be a problem!
If you over-fill the coolant tank, it will "burp" the coolant out until it is down to the correct level.
Does it keep losing coolant until the tank is empty? Or are you adding coolant every time that it burps it out?
Old 02-24-2015, 05:40 PM   #3
Rich04's Avatar
It comes out till there's nothing left in the overflow, if i have the car out i check on it and always carry coolant just incase to refill
Old 02-24-2015, 05:46 PM   #4
Hmmm.
In that case, I would try a new cap, or have yours tested, and try that.
A leaking head gasket can also cause this sort of problem.
Hopefully it's just a bad radiator cap.
Old 02-24-2015, 05:54 PM   #5
Rich04's Avatar
Hmmm.
I just dropped the motor in October, hope it's not the head gasket. I'm gonna try the cap and if that isn't it i guess overflow tank, then go from there.
Old 02-24-2015, 06:24 PM   #6
I am pretty sure its your head gasket or maybe a water jacket crack. The coolant coming out like that makes me think that combustion is forcing the coolant out. You should get a compression test done.
clinesr22 is offline   Reply With Quote
Old 03-02-2015, 10:12 AM   #7
Rich04's Avatar
Threw on my friends cap, nothing came out. I guess problem solved for now. Still gonna order a new tank.
Overflow Tank Toast Billymich 1979-1995 Mustang GT 3 10-12-2012 08:05 AM
overflow tank Gary C 1979-1995 Mustang GT 3 11-14-2011 05:37 PM
Moroso Aluminum Supercharger Coolant Tank (03-04 Cobra) drusmith SVT Mustang 13 11-02-2011 11:19 AM
Coolant Overflow Tube IMP Pre-2005 V6 Mustang 1 10-26-2008 12:38 AM
08:31 AM
