HELP BBK X PIPE - Mustang Evolution
Old 02-24-2015, 11:09 PM   #1
behemoth's Avatar
Region: Oregon
HELP BBK X PIPE
Installed bbk off road x pipe and my car is stumbling sluggish and dies at low rpm could this be exhaust leak at the manifold flange?
Sent from my SM-N910T using Mustang Evolution mobile app
behemoth is offline   Reply With Quote
Old 02-24-2015, 11:12 PM   #2
Steve96's Avatar
Maybe an 02 sensor giving you problems? Any codes?
1996 GT
Old 02-24-2015, 11:13 PM   #3
behemoth's Avatar
Region: Oregon
No codes I just hooked up bat and took off and it was running like this
Old 02-24-2015, 11:16 PM   #4
behemoth's Avatar
Region: Oregon
I was under the impression that when u hook up the bat the ecu would run closed loop until mixture was figured out
Old 02-24-2015, 11:32 PM   #5
joe_117's Avatar
Did you replace your right side gasket?
joe_117 is offline   Reply With Quote
Old 02-24-2015, 11:33 PM   #6
behemoth's Avatar
Region: Oregon
Yes
Old 02-24-2015, 11:34 PM   #7
joe_117's Avatar
Yes
No lose clamps, or leaks? O2 sensors in the right places?
Old 02-24-2015, 11:36 PM   #8
joe_117's Avatar
Also what do you mean stumbles sluggish
Old 02-24-2015, 11:41 PM   #9
behemoth's Avatar
Region: Oregon
Hard to explain bad performance it was hesitant when gas was pressed
Old 02-24-2015, 11:54 PM   #10
behemoth's Avatar
Region: Oregon
I'll look tomarrow can only be 2 things right? Can the mil delete cause any problems?
Old 02-25-2015, 12:01 AM   #11
joe_117's Avatar
Ummm im not quite sure. You don't have mil eliminators or a tune for the delay right?
---------- Post added at 06:01 AM ---------- Previous post was at 06:01 AM ----------
^delete
Old 02-25-2015, 12:03 AM   #12
behemoth's Avatar
Region: Oregon
I have mil eliminator for rear o2s
Old 02-25-2015, 12:23 AM   #13
joe_117's Avatar
Hm...that's odd. Maybe soccer, or someone could address this situation. I'm about to install my bassani x pipe, I hope this doesn't happen to me.
What I would do in your situation is
1) put your old mid pipe back
2) call BBK im sure they can help. Or at least try.
Old 02-25-2015, 12:26 AM   #14
behemoth's Avatar
Region: Oregon
I mean fitment doesn't seam like issue just wondering if something isn't seated or I damaged my o2
Old 02-25-2015, 12:27 AM   #15
joe_117's Avatar
Man you got me on this one Im clueless. It never did this with the stock mid pipe?
Old 02-25-2015, 12:29 AM   #16
behemoth's Avatar
Region: Oregon
Nope. Had a issues with clogged cat so I went aftermarket and now it's acting like a retarded donkey oppose to a mustang
Old 02-25-2015, 12:45 AM   #17
XSlashDashX's Avatar
You do lose low end with x pipe vs h pipe
Old 02-25-2015, 12:53 AM   #18
behemoth's Avatar
Region: Oregon
It's not that it's that my car is running like ****
Old 02-25-2015, 04:17 AM   #19
Steve96's Avatar
O2 sensor
1996 GT
Old 02-25-2015, 08:20 AM   #20
joe_117's Avatar
O2 sensor
What could cause the O2 sensors to go bad? Just curious. If I need to get new O2 sensors for myself before I swap my mid pipe il buy them.
Old 02-25-2015, 08:32 AM   #21
Brentap19506's Avatar
It has to be something with your O2 sensors. The codes just might not have popped up yet or they are there without the check engine light on. I've done quite a few mid pipe changes. Just take out the 02 connections and clean them out. Make sure the wires didn't rip anywhere
2000 Gt- Vortech V1 10psi, 4.10 gears, SLP LT headers, Magnaflow cat-back, Eibach pro-sport suspension, MM subframes, 78mm plenum and throttle body, lots of cosmetics, and more
Brentap19506 is offline   Reply With Quote
Old 02-25-2015, 08:55 AM   #22
O2 sensor issue or a leak. Or the set of MIL eliminators you got is wired up wrong or not clipped in all the way? It literally could be something that stupid. The pipe itself is not going to cause this so something got bumped/pinched/boogered somehow during the install.
Old 02-25-2015, 09:23 AM   #23
joe_117's Avatar
This thread got my worrying now lol. My x pipe will be in monday, and I hope everything goes well
Old 02-25-2015, 10:19 AM   #24
The_Chech's Avatar
I'm about to swap out my BBK xpipe out for the UPR one to hopefully fix the leak issue I have now
Oxford White Roush Stage 1 SN# 6925--SOLD but never forgotten!
Kona Blue GT premium - Slammed on BC's and BMR's full rear suspension
The_Chech is offline   Reply With Quote
Old 02-25-2015, 11:18 AM   #25
behemoth's Avatar
Region: Oregon
Yeah imma re check everything today I was just sad after removing to stripped studs that were the biggest pain just want it to run hahaha
Old 02-25-2015, 12:12 PM   #26
Steve96's Avatar
I have a small leak issue with my BBK as well. Let us know how the UPR works for you. I think you will have a Nice sound difference too.
1996 GT
Old 02-25-2015, 01:08 PM   #27
The_Chech's Avatar
HELP BBK X PIPE
When I bought the BBK xpipe I didn't realize it was a hybrid of an H pipe and Xpipe. I also was fortunate enough to get a one piece pipe so that's what might of caused some leaking issues with the drivers side connection to the manifold.
Old 02-25-2015, 01:12 PM   #28
behemoth's Avatar
Region: Oregon
I got the 3 piece off road
Old 02-25-2015, 01:34 PM   #29
natestang07's Avatar
My h had to be welded in the middle to get it to stop leaking.
Old 02-25-2015, 01:40 PM   #30
behemoth's Avatar
Region: Oregon
No leaks I could feel at the clamps or the flanges connecting to mufflers
---------- Post added at 07:40 PM ---------- Previous post was at 07:39 PM ----------
I think there might be leak at the manifold flange though
Old 02-25-2015, 04:00 PM   #31
The_Chech's Avatar
Mine literally rattles between 2200-2500 rpms at the driver side manifold. It's the worst sound ever. I've tried re-tightening multiple times. I even put a hose clamp around where the ball goes into the socket to help put pressure on it. It helped for awhile but I think the hose clamp broke. So this is another reason why I'm getting another Xpipe that comes in different parts to help out with angles.
Old 02-25-2015, 04:07 PM   #32
behemoth's Avatar
Region: Oregon
I've noticed this too
Old 02-25-2015, 04:33 PM   #33
HELP BBK X PIPE
Mustang_Tale is offline   Reply With Quote
Old 02-25-2015, 08:53 PM   #34
joe_117's Avatar
I ordered a bassani x pipe. Think I won't have any trouble with jt
Old 02-25-2015, 08:59 PM   #35
behemoth's Avatar
Region: Oregon
Well re adjusted everything seems good although mil eliminator won't fit
H pipe vs x pipe vs straight pipe 509pony 2005-2010 Mustang GT 100 02-15-2015 09:35 AM
06 gt catted shorty bbk x pipe on a 2012 gt with bbk longtube headers hdez41 2011-2014 Mustang GT 0 10-09-2014 12:47 AM
BBK Long tube headers and BBK Catted X-Pipe Rexex 2011-2014 V6 Mustang 8 10-07-2014 06:36 AM
JLT CAI with Steeda spacer, or BBK CAI and BBK throttle body? Aventador97 2005-2010 V6 Mustang 11 02-26-2014 04:12 PM
Just ordered some BBK Longtubes and BBK O/R H-pipe wc3john 1979-1995 Mustang GT 62 07-13-2011 04:17 PM
03:43 PM
