Tumbling noise please help - Mustang Evolution
Old 02-25-2015, 01:11 PM   #1
robin_gt's Avatar
So when you drive there is a tennis shoe in a dryer kinda noise and it increases with speed it is definitely coming from the front end of the car and doesnt get worse with turns. What could this be? Thanks in advance
robin_gt is offline   Reply With Quote
Old 02-25-2015, 01:12 PM   #2
robin_gt's Avatar
Its a 2000 v6
Old 02-25-2015, 04:09 PM   #3
Can you feel any vibration through the steering wheel?
I would, very carefully, inspect the front tires for any signs that the tread is separating from the tire. Sometimes, a cord can break, inside of the tire, and the tire tread will become misaligned or bulged (Separated) in the area of the broken cord and the tire will make a strange noise.
Old 02-25-2015, 04:52 PM   #4
robin_gt's Avatar
it´s kinda hard to hear but the noise occurred after replacing the rotors and pads,
also dropped the lower control to take access the caliper bolts with an impact. so it may be a swaybar noise?
Old 02-25-2015, 05:10 PM   #5
I can hear it. It sounds like something is rubbing. Whatever it is, it must be leaving a rub mark somewhere.
You will probably have to take the wheels off and give it a thorough inspection. Pay close attention to everything that you worked on.
Maybe the dust cover got a little bit bent and and is rubbing the rotor, or something like that.
Old 02-25-2015, 05:11 PM   #6
robin_gt's Avatar
ok i will thanks for the advice
Humming noise, please help! 99redbeast General Mustang Discussion 1 11-21-2011 07:18 AM
Nasty noise under the hood please help! S197STANG 2005-2010 Mustang GT 18 11-05-2011 10:14 PM
2011 front end noise question. Help please drivinglesson 2011-2014 Mustang GT 15 08-31-2011 01:38 PM
Clutch noise?? Please help! Hyphynator 1979-1995 Mustang GT 11 02-04-2011 11:59 PM
08:21 AM
