Weird spinning noise. - Mustang Evolution
Old 02-25-2015, 05:07 PM   #1
alecas447's Avatar
Hi guys, I've been having a weird spinning noise coming for my my front right wheel since I bought It i never really paid it any attention.
But just want to make sure my wheel is not going to fall out or something. What can this be I've been thinking it could be the wheel bearing. But I'm not to sure.
It only makes that noise when braking to a stop or just slowing down to a stop. Thanks!
alecas447 is offline   Reply With Quote
Old 02-25-2015, 06:11 PM   #2
natestang07's Avatar
It is not a brake related noise at all? My old Nissan did this and when I pulled the pads They were worn really unevenly and had to end up getting rotors and new pads
Old 02-25-2015, 06:20 PM   #3
alecas447's Avatar
The car brakes fine. Although I've never gotten them checked. Would a worn rotor make that weird noise?
And it only comes from one wheel so I don't see how it can happen with just one and not both rotors simultaneously, assuming they were put on at the same time.
Old 02-25-2015, 06:43 PM   #4
I had my left rotor fine and my right one was messed up. When you get some time just pull a pad out and look at it
Old 02-25-2015, 10:08 PM   #5
alecas447's Avatar
Hand tools to remove rotor and pads?
Old 02-25-2015, 10:14 PM   #6
Panther140's Avatar
Depends on your arm strength, rustiness of parts, and wrench handle length lol. I do it alright with just my ratchet and sockets. But once you get the wheel off, you will be able to see the rotor and pads clear enough to see if you need replacement parts. My bet is on worn brake pads and some rotors that need to be turned at the least.
For reals though, you can get a $30 1/2" drive impact from wal mart that will save precious hours of your life when combined with even just a little air compressor
Panther140 is offline   Reply With Quote
Old 02-25-2015, 10:29 PM   #7
My parents expy rotor was seized to all hell and took us forever. The pads will come off easy enough though and from there you will be able to tell the status of the rotor
Old 02-25-2015, 10:34 PM   #8
Just going to put this out there...
If you replace the rotor go with an oem rotor and not a cheap Chinese rotor. Trust me on this...
Adventure till you drop
Old 02-25-2015, 10:35 PM   #9
This lol. Learned that The hard way also
Old 02-25-2015, 10:37 PM   #10
No, replaced the garbage on customer cars...
My ***** gets the good stuff...
Old 02-25-2015, 10:47 PM   #11
alecas447's Avatar
Thanks.
So what if they are I'm good condition. Can it be the wheel bearing , do they make those strange noises?
Old 02-25-2015, 10:58 PM   #12
Possibly, as you might know it's difficult to diagnose a problem over words on a screen. But rotors and pad check first then check them...
If they are Chinese rotors throw them away immediately. The metal compound in the rotor is incredibly weak, they warp very easily...
Old 02-26-2015, 10:45 AM   #13
alecas447's Avatar
Yea I know. I was trying to upload a video maybe you guys know what the sound is but its letting me right now. As for rotors is it better to get them online or just nearby auto store.
Old 02-26-2015, 04:22 PM   #14
Probably online. We only have AutoZone here and they didn't have oem stuff. Order from rock auto and track down the 6 percent code
Old 02-26-2015, 05:59 PM   #15
Panther140's Avatar
If you cant afford a brand new rotor, just get the OEM one turned and that will last you until you can get one. Turning a worn out rotor that's high quality always works out better than replacing a worn out good rotor with a brand new cheap rotor.
Old 02-27-2015, 09:04 AM   #16
XSlashDashX's Avatar
Would get it checked before throwing parts.
Old 02-27-2015, 08:53 PM   #17
thyreaper's Avatar
Wheel bearings usually roar/wine more the faster u go they typically don't make more noise when u slow down
thyreaper is offline   Reply With Quote
Old 03-03-2015, 11:35 AM   #18
alecas447's Avatar
Ok so for now it makes the noise when the cars i am driving mostly noticeable at low rpms. Few what it seems it has nothing to do with braking.
Old 03-03-2015, 07:11 PM   #19
DetroitMuscle99's Avatar
Drive the car about 25 to 30mph. Steer hard from left to right like NASCAR guys do to clear their tires of dibrees and warm them up before a restart. Does the noise happen? It could also be your front hub assembly. Jack the car up when your going to check your brakes and rotors. Grab your front wheels and might as well check the back to for any play try and rock the wheel and tire back and forth. Push on top and pull out on bottom and vise versa. If there is any play replace the hub assembly.
This is why we play the game... to separate the contenders from the pretenders!
DetroitMuscle99 is offline   Reply With Quote
Old 03-03-2015, 07:17 PM   #20
alecas447's Avatar
From visual, there is some bent metal in there. Behind the rotors
Old 03-03-2015, 07:27 PM   #21
Well that's not good get hands on that's the only way you will know what's really going on.
Old 03-03-2015, 07:35 PM   #22
alecas447's Avatar
Wish I had the time. It's been like that for 6 months and nothing yet
Old 03-04-2015, 12:04 PM   #23
fomoco4life's Avatar
The dust cover behind my rotor was bent, and it made all kinds of crazy noise. Bent it out, fixed it
Old 03-04-2015, 12:08 PM   #24
alecas447's Avatar
Name:	ImageUploadedByMustang Evolution1425496050.159853.jpg
ID:	176658Click image for larger version
Name:	ImageUploadedByMustang Evolution1425496075.175785.jpg
Old 03-04-2015, 07:03 PM   #25
Attachment 176658Attachment 176660
That could be the cause.
Old 03-04-2015, 07:06 PM   #26
alecas447's Avatar
What is that?
Old 03-04-2015, 07:18 PM   #27
What is that?
What the previous poster said... Its the brake dust cover for the rotor. Is yours touching/rubbing the rotor?
Old 03-04-2015, 07:44 PM   #28
alecas447's Avatar
Ah I see and not sure I'll check in the AM
Old 03-04-2015, 07:53 PM   #29
Dude lol you've been on The forum all night you could of been checking your ride or pushing your beamer down the block making turbo noises haha.
Old 03-04-2015, 07:58 PM   #30
alecas447's Avatar
Nah I do a bunch of homework at this time everyday.
You should be towing your car down the block tho lol😂
Old 03-04-2015, 08:03 PM   #31
I'll swing by and tow your beamer to the shop , drag your *** down the street. Than fix your mustang for you. Haha all in good fun bro...
Old 03-04-2015, 08:08 PM   #32
alecas447's Avatar
I'd love to see that dude. Someone like you? You sound like you have some serious personal issues man. Most of the time you just come on here and all you do is troll, sometimes it's funny but dude give a rest.
If you want to race, I already told you I'll rent a Prius and I'll give your tow truck a head start. Maybe just maybe your car can beat me like that.
Old 03-05-2015, 04:02 AM   #33
I was joking with you but for one I don't come on here trolling. Secondly I help whoever I can out with their car troubles. I don't have personal issues but if that's What you think good for you. Lastly you would never beat me in a race. I should of never gave you guidance in your issue now that I look back on what you've said before but I did anyway. Go figure....
Old 03-05-2015, 02:14 PM   #34
alecas447's Avatar
As soon as the car cools down. I'm going to fix the bent. What tool is recommend for this?
Old 05-23-2015, 04:05 PM   #35
alecas447's Avatar
Ok so the noise isn't a bad wheel bearing.
It's a weird spinning noise and seems to be coming from the differential. Only happens when I let go of the gas an coming to a stop.
What are the symptoms for a differential going out?
Spinning noise after clutch install. sam13708 1979-1995 Mustang GT 8 08-31-2012 10:37 PM
spinning tires Jimmygun911 1979-1995 Mustang GT 9 07-06-2012 11:33 PM
Spinning tires TreyBo 2005-2010 V6 Mustang 19 06-04-2012 07:18 AM
Spinning one tire 02utahgt 1996-2004 Mustang GT 7 04-17-2012 10:07 AM
only one wheel spinning on my 1996 mustang gt vinnygt 1996-2004 Mustang GT 9 06-15-2011 08:58 PM
03:24 AM
