AM Exhaust doesn't fit - Mustang Evolution
Old 02-28-2015, 05:56 PM   #1
SquatchMan's Avatar
Really frustrated with American Muscle right now. Tried to install the Flowmaster American Thunder Catback with floor jacks (which the instructions said would work). I cut off my stock exhaust and put on my mufflers and I was about to put on the axle backs, but they don't fit. Tried to get them on for over an hour, there's no way. Now I'm stuck at home with no exhaust on my car. What do I do? I have to go back to college tomorrow and all my shops are closed. Thanks a lot AM.
40th Anniversary GT
04 GT
SquatchMan is offline   Reply With Quote
Old 02-28-2015, 06:02 PM   #2
DiESeven's Avatar
They're not fitting to what? The muffler? Pics?
Old 02-28-2015, 06:07 PM   #3
1, why did you CUT your exhaust? 2. It's not AM's fault, they don't make the exhaust, that's Flowmaster.
Sounds like your blaming them for your mistake.
Old 02-28-2015, 06:15 PM   #4
DiESeven's Avatar
For his year, you have to cut your exhaust in order to remove it from the car to install the flowmaster catback.
Old 02-28-2015, 06:15 PM   #5
SquatchMan's Avatar
You have to CUT it in order to get it off. It's in the instructions.
40th Anniversary GT
04 GT
Old 02-28-2015, 06:17 PM   #6
SquatchMan's Avatar
The part that goes over the axle from the muffler to the bumper. There's no way to get it over the axle, it hits some part of the car from every angle
40th Anniversary GT
04 GT
Old 02-28-2015, 06:21 PM   #7
SquatchMan's Avatar
Name:	ImageUploadedByMustang Evolution1425172807.907811.jpg
ID:	176370Click image for larger version
Name:	ImageUploadedByMustang Evolution1425172836.838358.jpg
ID:	176371Click image for larger version
Name:	ImageUploadedByMustang Evolution1425172860.147901.jpg
ID:	176372Click image for larger version
Name:	ImageUploadedByMustang Evolution1425172873.454967.jpg
The pipes are supposed to wrap around the axle and bolt to the muffler.
40th Anniversary GT
04 GT
Old 02-28-2015, 06:23 PM   #8
Slater2111's Avatar
Try raising the car up in the rear to allow the axle to drop down a little. You don't need to raise it off the ground. Just take some weight off the rear. Then you should be able to slip them around it.
Sent from the mothership.
Slater2111 is offline   Reply With Quote
Old 02-28-2015, 06:24 PM   #9
DiESeven's Avatar
Are you sure you've tried every angle? Have you tried lining it with the rear axle to slip it through, then rotate it 90 degrees so the tip is at the rear, then turn it so it is oriented correctly?
Old 02-28-2015, 06:24 PM   #10
Slater2111's Avatar
They will fit. It's just finagling them in there
Old 02-28-2015, 06:27 PM   #11
SquatchMan's Avatar
Trust me. I tried every angle. There's brackets welded to the pipe that don't allow them to fit around the axle. I took the wheels off and I had the back of the car sitting like 3 and a half feet off the ground. Click image for larger version
Name:	ImageUploadedByMustang Evolution1425173185.422141.jpg
40th Anniversary GT
04 GT
Old 02-28-2015, 06:34 PM   #12
DiESeven's Avatar
Old 02-28-2015, 06:35 PM   #13
BigD's Avatar
Why are you complaining about AM? They don't make the products.......
BigD is offline   Reply With Quote
Old 02-28-2015, 06:49 PM   #14
Black8thElement's Avatar
Damn bro, i hope you get that taken cared of... worst comes to worst you may have to leave her and get it towed to a shop.
"Good luck with that"
Black 2008 Decepticon GT "If it ain't hooking, it ain't booking" edition
Black8thElement is offline   Reply With Quote
Old 02-28-2015, 07:04 PM   #15
SquatchMan's Avatar
Yeah, it'd be great if I had a car lift. Haha
40th Anniversary GT
---------- Post added at 08:04 PM ---------- Previous post was at 08:03 PM ----------
I'm complaining because AM said you could do it from the ground. And you can't. I would've had a shop do it if they woulda put that on the instructions.
40th Anniversary GT
04 GT
Old 02-28-2015, 07:05 PM   #16
SquatchMan's Avatar
Thanks bro. It majorly sucks, I think my brother is gonna take it somewhere for me next week.
40th Anniversary GT
04 GT
Old 02-28-2015, 07:16 PM   #17
Slater2111's Avatar
I put my cars cat back on with the car on ramps. But I have a different cat back. It wasn't hard at all. Sucks you're having such a difficult time.
Old 02-28-2015, 07:16 PM   #18
DiESeven's Avatar
I mean, the fact that a customer submitted installation instruction shows it being done on jackstands must mean you're not trying all angles.
Based on your pics under the car & the pipes, I don't see why it's not fitting. I can even go through the motion in my head with it fitting in lol. Did you try with them upside down, slide the hanger part in, then rotate the whole thing at an angle to slip the rest through?
Old 02-28-2015, 07:44 PM   #19
Slater2111's Avatar
Double post
Old 02-28-2015, 07:44 PM   #20
SquatchMan's Avatar
Yep. We literally tried every possible angle on both pipes. The car had to be at least another couple feet off the ground for it to fit. My dad and I both spent an hour on it.
40th Anniversary GT
04 GT
Old 02-28-2015, 07:59 PM   #21
alecas447's Avatar
I purchased O2 extensions yesterday. They will not fit no matter what.
I might have to get some electrical tape to get them on
alecas447 is offline   Reply With Quote
Old 02-28-2015, 09:30 PM   #22
Originally Posted by SquatchMan View Post
Attachment 176370Attachment 176371Attachment 176372Attachment 176373
40th Anniversary GT
You need to take the load off the rear axle. Won't work otherwise. Jack it up and brace it to where the rear axle can hang.
Old 02-28-2015, 09:55 PM   #23
SquatchMan's Avatar
I did. I took the pics after I already gave up.
40th Anniversary GT
04 GT
Old 02-28-2015, 10:38 PM   #24
FYI even flowmasters instructions stat '1) Raise the vehicle up on a hoist or rack to working height. If you don’t have access to a hoist or rack, raise the vehicle and support securely with jack stands.'
So clearly its possible to install them without a lift. Installations like this are never as simple as connect bolt A to bolt B. There is always some playing around with it to get it to fit right. Have you tried adjusting the jackstands to different heights? I would question if you tried every possibility if you only spent an hour trying to get it to fit.
StarzTA17 is offline   Reply With Quote
Old 02-28-2015, 10:38 PM   #25
natestang07's Avatar
You might have to pull a prong or shave it down to fit. I had to
Old 02-28-2015, 11:01 PM   #26
There is always unbolting the control arms and dropping the axle...
Old 02-28-2015, 11:07 PM   #27
alecas447's Avatar
Pull a prong?
I shaved both sides on both female connectors it still won't clip on the sensors
Old 02-28-2015, 11:15 PM   #28
Pull a prong?
Sometimes there is an extra prong in,there since they are universal for years. Obviously yours is fine, just try to keep shaving
Old 02-28-2015, 11:18 PM   #29
alecas447's Avatar
I'm telling you bro it goes in but does not clip on. I might just use some electrical tape or something
Old 02-28-2015, 11:52 PM   #30
oxford5pointoh's Avatar
Is your car lowered? Maybe this is possible on a stock springs but if lowered makes it impossible from jack stands. I know my car isn't even close to yours but when I did mine (3" magnaflow cat back) I also had to work hard to get the over axle pipes in. I had to jack the car up stupid high in the back and move a jack stand that was in my way. It was a bit@h. But I got it. And my car isn't lowered. Like another guy said, why not just drop the axle if you can't get it any other way. Prob take an extra hour.
Old 03-01-2015, 07:12 AM   #31
SquatchMan's Avatar
I had the jack stands on top of 4" blocks jacked all the way up. My back bumper was like 3 feet off the ground. And no it's not lowered. I spent an hour just trying to get 1 pipe to go over the axle.
40th Anniversary GT
---------- Post added at 08:12 AM ---------- Previous post was at 08:11 AM ----------
Is that not like super hard?
40th Anniversary GT
04 GT
Old 03-01-2015, 08:04 AM   #32
No. Load the suspension a little with a Jack, unbolt the lower control arms at the axle side and then CAREFULLY AND SLOWLY unload the suspension till you have room. Easy peasy and you'll be done today.
Old 03-01-2015, 11:00 AM   #33
Hellish Horse's Avatar
If the Hanger is stopping it.
Cut the hanger off. Install the exhaust & have the hanger welded back on for $20.
I take it you tried both pipes on each side in case one was a little different ???
Hellish Horse is offline   Reply With Quote
Old 03-01-2015, 11:02 AM   #34
69mach1390's Avatar
I also had to drop the axle housing a little to get it to turn into place
69mach1390 is offline   Reply With Quote
Old 03-01-2015, 11:28 AM   #35
SquatchMan's Avatar
Yeah tried that.
40th Anniversary GT
04 GT
exhaust
Will 205/75-14 tires fit 14x7 wheels? will 225/45-17 tires fit 16x8 wheels? baudier Classic Mustangs 4 03-29-2016 08:25 PM
2014 exhaust that doesn't stick out saleenfanning 2011-2014 Mustang GT 25 03-16-2014 09:48 PM
Exhaust that doesn't pop? 86GTFoxBody 2005-2010 Mustang GT 29 06-14-2012 02:27 PM
Can a 1969 power steering fit in a fit in a 1967 mustang? buchanan Classic Mustangs 2 12-11-2011 08:10 AM
Will the performance parts that fit a 4.6 mustang fit a 4.6 lincoln town car? ruhleah General Mustang Discussion 4 04-09-2010 12:33 PM
04:12 PM
