Swapping exhaust - Mustang Evolution
Old 03-01-2015, 10:24 PM   #1
joe_117's Avatar
Swapping exhaust
So I've made my mind to swap my catback. Simply because of the performance it caused. Any suggestion? I know borla is praised but what about bassani, magnaflow?...
joe_117 is offline   Reply With Quote
Old 03-01-2015, 11:13 PM   #2
Steve96's Avatar
Bassani and magnaflow are both great companies. Either one will be comparable as far as performance. I'm sure there are sound differences between them of course. What was the performance issue you have currently? I would just get a off road mid pipe, x or h, some high flow mufflers welded in (magnapacks, flowmaster, slp, borla, etc, etc on and on). Your exhaust choice won't make a huge power difference no matter which route you take, It's mostly to allow the engine to breath better and get a better exhaust tone, loudness level, etc.
1996 GT
Old 03-02-2015, 12:27 AM   #3
joe_117's Avatar
My off road bassani x pipe came in. It's awesome, and I currently have slp loudmouth ones. But I lost low end torque. I even called late model restoration and asked them an they said yes it does do that. I knew something was different when I swapped my flowmasters with this set. I love the sound, it sound great, but I don't like what it did. When I got the car I could punch it and my body go back, but with this I really don't.
It's said back pressure but I'm sure that's just lies or something. It could be the diameter of the resonator. But I did lose low end torque
Old 03-02-2015, 12:29 AM   #4
joe_117's Avatar
I also will install my bassani x pipe tomorrow or Tuesday. Depending on the weather (: . I want you guys to give me an opinion on the tone once I do to! Il make a rev, fly by, etc videos!
Old 03-02-2015, 12:33 AM   #5
2 Stangz's Avatar
Region: Nevada
Do you have a tune or no?
Old 03-02-2015, 12:37 AM   #6
joe_117's Avatar
No tune yet, process of data log tho. Ortiz tune that is. Once I send it in il have it tho. But it'll be a bit before I get a tune tho..:/
Old 03-02-2015, 02:53 AM   #7
2 Stangz's Avatar
Region: Nevada
I think with the proper tuning, you may be able to get back that low-end torque you said you're missing with your new O/R X. Or at least get some back.
Old 03-02-2015, 05:22 AM   #8
joe_117's Avatar
Ya I probably could. I just think maybe Slp is more of a exhaust tone resonator rather than getting performance. Bassani, magnaflow is a different story
Old 03-02-2015, 02:50 PM   #9
Slater2111's Avatar
I think it's a placebo effect you're feeling. I have slp loudmouths and I definitely gained some low end and mid range. But I have a tune intake TB and plenum backing mine up.
Sent from the mothership.
Slater2111 is offline   Reply With Quote
Old 03-02-2015, 07:47 PM   #10
joe_117's Avatar
It's your other mods man. It has to be. I swear i Lost low end. Believe me, I love this exhaust but I'd rather have performance rather than sound. If that makes sense.
Old 03-02-2015, 07:56 PM   #11
Slater2111's Avatar
Swapping exhaust
Open up your intake!
Trust me it's worth it!
Old 03-02-2015, 08:22 PM   #12
joe_117's Avatar
New Plenum, tb, intake? That about it?
Old 03-02-2015, 08:37 PM   #13
Slater2111's Avatar
I kept my stock intake tube. It works well enough. Plenum and TB are a must. Biggest recommendation you'll get around here is the summit racing plenum and TB combo. It's cheap and is made by trick flow. It works well from what I hear. I did a 75mm C&L plenum and 70 mm TB. It will really wake your car up. Best to have it tunes tho to take advantage of the increased airflow.
Old 03-02-2015, 08:39 PM   #14
joe_117's Avatar
What tune?
Old 03-02-2015, 09:42 PM   #15
I agree you'll definitely feel a difference and like he said get the summit racing one it is made by trick flow just doesn't have the name and is cheaper
04sonic is offline   Reply With Quote
Old 03-02-2015, 10:26 PM   #16
joe_117's Avatar
What cite
Old 03-02-2015, 11:57 PM   #17
Steve96's Avatar
Summit racing
1996 GT
Old 03-03-2015, 04:42 AM   #18
Slater2111's Avatar
I have MPT as a tuner. Summit racing sells their TB and plenum combo. It's a good unit made by trick flow.
Old 03-03-2015, 06:11 AM   #19
When I first put my lm1 on I didn't notice one bit of power taken away
Old 03-05-2015, 09:12 PM   #20
You do realize all the catbacks are within about 2hp of each other at these power levels right?
Old 03-05-2015, 10:55 PM   #21
joe_117's Avatar
Ya I understand. I just don't like what SLPs did. Sound is great but I just would rather go with bassani
exhaust
swapping the rear from the 90 into the 64? fast64 Classic Mustangs 8 04-27-2006 10:13 PM
How-to: Swapping a late model, EFI 5.0 and a t-5 into your classic Mustang fast64 1979-1995 Mustang GT 8 05-29-2005 04:15 PM
The Official V6Stangs File Swapping Thread! ItWouldAppearSo The Bar 21 10-22-2003 04:30 PM
Swapping brakes Rellik Pre-2005 V6 Mustang 11 10-16-2003 07:06 PM
06:15 PM
