Forged internals - Mustang Evolution
Old 03-03-2015, 09:45 AM   #1
33wings's Avatar
Forged internals
What will it take to raise what a 2000 can handle horsepower wise?
33wings is offline   Reply With Quote
Old 03-03-2015, 11:11 AM   #2
If you want to "safely" go above 450 rwhp, it is recommended to forge the entire rotating assembly... Crank, rods and pistons.
If you are a gambling man, you may be able to get away with just using forged rods and pistons.
Old 03-03-2015, 02:08 PM   #3
A well balanced cast crank can handle a good amount of power and rpms, it's also lighter than forged steel.
Old 03-03-2015, 02:21 PM   #4
The same can be said for using quality Hypereutectic pistons instead of forged.
Old 03-05-2015, 09:04 PM   #5
Beyond what the stock rotating assy can take? Forged internals/ported heads and new cams and then a power adder to take advantage of it and then a built driveline to get the power to the tires and then fully going through the chassis and suspension so the power at said tires actually goes to the pavement. $12-$15k plus whatever you paid for the car before factoring in labor if you aren't diy.
If you don't need more than 425 rwhp, Vortech, bolt ons and go.
Old 03-06-2015, 10:58 AM   #6
Panther140's Avatar
Your rods need a damn good tune just to handle 450. Id get some H beam rods if I was going 400 rwhp - 550 ish. Anything 600 plus and you should probably get an entire forged rotating assembly.
And thats just the engine.
You need a good trans to hold all of that power
And driveshaft. and rear end/axles too.
Suspension is important. Drag slicks are good if you're going WOT from a dig all the time
Panther140 is offline   Reply With Quote
Old 03-06-2015, 11:00 AM   #7
Panther140's Avatar
Theres a reason that the average joe doesnt have a 10 second car
forged internals dhktactical Pre-2005 V6 Mustang 0 05-23-2012 07:48 PM
forged internals allen1998gt 1996-2004 Mustang GT 6 05-20-2012 03:47 PM
forged internals br10301 1996-2004 Mustang GT 2 02-28-2012 10:48 PM
Forged internals Blackedout Pre-2005 V6 Mustang 29 02-22-2012 04:42 PM
forged internals!? 97V6stangct Pre-2005 V6 Mustang 2 01-19-2012 02:59 PM
04:44 AM
