Since my Mach 1 is not my daily driver anymore, I finally got Eibach Sportline lowering springs. Right now, I am just rolling with the stock shocks and struts. I've been looking at a couple of brands and wondered about Koni's.
I'll mainly be casual driving, crusing, and about 5 visits to the drag strip per year.
Has anyone tried the KONI STR.T non-adjustable struts? I would get all the same brand/model of these, AM just doesn't sell them together.
I don't know anyone that have used the non-adjustable Koni's but I know several people with the adjustable Koni's and I have never heard any complaints.
It sounds like you don't need anything too fancy, for your intended use of the car, so a set of good quality non-adjustable shocks/struts will probably suffice.
I have Koni STR. T shocks, and Tokico HP struts and I can say I like them both. I mis matched mine due to a in stock issue at the time and I needed the struts to finish the job That's Why they aren't all the Konis. I believe they are a good product honestly. Never have heard anyone complain of those or the Tokicos HPs I have.
It's a bit bouncier than stock and not as stable feeling on the highway. I got spring that were pretty close to the stock ones for the Mach 1's spring rate, but it's still needs new shocks and struts. I think it will be great when I pickup some replacements. I just need to pull the trigger now lol.
I hate the 4x4 look mine had but every time I get ready to order springs someone's talking about a crappy ride and damn mine rides better than my toyota 4 runner hate to loose that! Lol
Illuminas are adjustable.
The Tokyo HP series are non-adjustable.
I have a set of Illuminas, by the way, and I like them. My only complaint is that one of the adjusters on the shock absorber broke almost immediately. It still can be adjusted but not as easily.
My other car is going to get a set of Konis...
I think I might go ahead and give the Koni STR.T's. Right around $300 for the set. I'm thinking if I don't think they are up to par in performance, I can upgrade later. I think it's worth a shot and I won't be subjecting my Mach to a lot of un-dampened drive time. I hear it can be bad for tire wear too.
Is there any additional hardware or bushing, etc that I should get for the struts up front?
For the white one, i have boxes of parts to get on too.
Koni STR shock/strut, H&R SS, CC plates, X2 balljoints, bump steer kit.
Cant wait to finally get those gems on too.
-The green car is slammed with same parts, different makes. The lowering makes it fell safely stuck to road when making turns at any angle, any high speed. Feels safe, better.
I started installing the Koni SRT.T's on my Mach this weekend. I ran into a bit of a problem.
I got the drivers side done, but on the passenger, I had a prob. The top stud of the shock got stripped and I couldn't tighten the shock. I tried to file it flat and the first attempt after filing it, the stud snapped off lol.
I was worried that I wouldn't be able to get the shock out to replace it, so I got my wife to help while I stuck a pipe wrench down below on the shock itself.
How do you guys normally tighten the top of the shocks? I was told by a few that they would lower the car a bit and tighten the tops and the weight would hold the shock in place. I need to try a hopefully get a replacement shock.
Latemodelresto would not give me a replacement for theater shock, so I just bought one from AM. They still have them on sale so that worked out okay.
I feel like given the amount of paint that was on the thread and the lock but that was on the Koni, it made it tough to install them the way I did. Since the tip snapped off, I really think LMR should offer a replacement, but oh well. :meh:
You probably lost LMR when you mentioned using a pipe wrench...
Normally, once the shock absorber is bolted to the axle, and the top is in place, with the car sitting on the ground, the pressure from the gas filled shock absorber is enough to hold the shock absorber in place while tightening it.
For cases where you can't tighten the top mount without the shock spinning, there are specialty sockets that fit the top of the shock absorber so that you can keep it from spinning while tightening the nut.
Such as these:
Sent from my SAMSUNG-SGH-I747 using Mustang Evolution mobile app
That's what I'll do when I get this new shock. I am going to go ahead and pickup a air impact wrench though. I have a feeling I'll need it down the road. Yes!! One of those sockets would have been very handy lol.
The pipe wrench chewed it up a bit getting it out. I should have just waited, but I figured they would want the old one lol. I thought about punting it, but honestly, it wasn't worth all that effort. It was only $52 to buy one from AM. I guess I have a spare.
Latemodelresto was probably right not to send a replacement, but I had to try. If I just would have left the one that snapped in there and lowered the car a little, I would have been able to tighten it. Everyday is a learning day for some of us. :lol:
Here's my pipe wrench handy work lol.
With a new shock, I won't have to worry about when it will rust or what it looks like when I'm at car shows, etc.
I didn't have enough money to do it all together, but I did consider the Eibach shocks and struts kit before I went with the Koni's. Initially I was dead set on Bilstein's, but I figured that the best of the best. I didn't think with what I'd be doing with her that I would need the best, so I decided on the Koni STR.T's
I see the Koni's are on sale really cheap. would you recommend me buying them vs looking for another option? another 100 or so and could pick up something else but I always hear the Koni brand being mentioned
there 300 for the shocks and struts on sale rite now am and lmr
with springs and cc plates the price jumps significantly. Looking at coil over kits that would only be a few hundred more
I like them so far in the back. Nice price for great quality. I figure it would be best to try these than go for some super high performance ones and pay for something I wouldn't take advantage of.
Got the replacement shock I bought from AM this week and put it on with no issues.
I don't have a tap and die set, so I used one of the nuts to clean some of the paint off the shock top threads.
Easy-peasey this time around.
I still need to do the struts. I drove her to work today and I could tell the back end was more under control on the highway. Can't wait to get the struts on.
I ended up buying a set of Maximum Motorsports caster camber plates from AM today. I got to thinking why am I buying strut bushings and all that for something I'll end up replacing later this year.
Got to grow a pair now and install them with the struts lol.
When you drilled the extra hole, did you have a lot of trouble getting through? It's pretty thick. I thought I'd try stepping it with smaller sizes and increasing up to the size needed.
IG: @azurebluemach
Related Threads
Mustang Evolution Forum
2.1M posts
50.8K members
Since 2003
