PCV Valve Elbow - Mustang Evolution
Old 03-07-2015, 11:14 AM   #1
escottcarp's Avatar
PCV Valve Elbow
It's usually a 5-minute job to replace a PCV valve. However, this time, I can't figure how to get that 90 degree elbow off the valve. It looks like it is heat shrunk onto the valve.
Thanks
Have a big Mustang day!
escottcarp is offline   Reply With Quote
Old 03-07-2015, 11:33 AM   #2
Pull real hard!
It will come off.
Old 03-07-2015, 01:08 PM   #3
escottcarp's Avatar
We are talking about the same part, right? I can't get even move the elbow off. Click image for larger version
Name:	ImageUploadedByMustang Evolution1425758889.826539.jpg
Old 03-07-2015, 01:30 PM   #4
No. Apparently, we are not.
That part in the picture isn't the PCV valve. It connects to a hose that is connected to the air intake upstream of the Throttle Body correct?
On the opposite valve cover, there should be the PCV valve and the hose that it is connected to should be attached somewhere downstream of the Throttle Body, on the plenum or the intake manifold.
Old 03-07-2015, 02:08 PM   #5
escottcarp's Avatar
Ok. Isn't the PCV valve on the passenger side valve cover (SOHC)?
This piece came off the passenger side valve cover.
Thanks.
Old 03-07-2015, 02:11 PM   #6
fenixignition's Avatar
that is the pcv valve. the drivers side one is just a vent. not rattling piece in it. i take it you bought a new one, and it did not have a 90 degree angle on it? i just left it on the old one and stuck the hose straight on it. maybe a motorcraft one will have the 90 degree piece on it, but the autoparts store brand did not.
2002 GT 5sp. 16x,xxx miles
Old 03-07-2015, 02:30 PM   #7
escottcarp's Avatar
Thanks.
This item I bought is the Motorcraft part. It does not have the elbow. The tube isn't long enough to connect to it without the elbow.
I guess it is almost impossible to remove the elbow?
Old 03-07-2015, 02:33 PM   #8
Here is what the PCV valve looks like on my Bullitt. It is just a standard valve that they have been using for 35+ years.
My car is different than the GT's and I think that everything is on the opposite side as the GT's. My PCV is on the passenger side valve cover.
Perhaps the PCV valve is completely different on the GT's? I've never seen one with threads and an o-ring like that one pictured.
Sent from my SAMSUNG-SGH-I747 using Mustang Evolution mobile app
Old 03-07-2015, 02:57 PM   #9
Did see some research. All of the 2V PCV's are on the passenger side. It's the 4V that is on the drivers side.
Regardless, that is the damndest looking valve that I have ever seen.
The elbow on the valve that I showed, will pull right off. Try putting your PCV valve in some hot water to soften up the plastic and then give it a good tug.
Old 03-07-2015, 04:23 PM   #10
escottcarp's Avatar
PCV Valve Elbow
That sounds like a good idea. If it works, I'll quickly put the elbow on the new valve.
Old 03-07-2015, 07:42 PM   #11
Theres 2 part numbers for the pcv valve, but I havent seen pictures of each one. I assumed one is like mine, straight piece, and maybe the other is a 90 degree. Both fit, just a matter of making the hose fit. I remember mine being a bit tough but I cant remember how I made it work.
Sent from my GT-P3113 using Mustang Evolution mobile app
Old 03-07-2015, 08:00 PM   #12
The PCV valve is actually different on my two Bullitts. The one in the picture is a standard valve. The PCV valve on my other car is a heated valve. It has a coolant line that wraps around the valve, heating it. I don't know the purpose of that but it may have something to do with CA emissions. It still just pops into the grommet like most of them.
I looked at the PCV on a Grand Marquis that I have and that one is the straight up style without the 90 degree elbow. It also just pops into the grommet on the valve cover... No threads.
Old 03-07-2015, 08:47 PM   #13
escottcarp's Avatar
Straybullett,
Your picture shows the same elbow as on my GT. How hard is it to take the elbow off the PCV valve?
Thanks
Old 03-07-2015, 09:00 PM   #14
The elbow pulled right off of that valve.
Old 03-08-2015, 03:27 PM   #15
escottcarp's Avatar
After heating the elbow/PCV valve in a very hot water bath, I still can't separate the two. I'll just get another elbow to finish the job.
FYI: the Motorcraft part I purchased is EV-257 and it does not include the elbow.
Thanks for the help!
Old 03-08-2015, 03:43 PM   #16
That damned PCV valve had me curious so I did a little more research and they did change the design on the later cars.
I'm guessing that your car is a 02-04.
Looking at Rockauto, it seems like all of the non-heated Motorcraft PCV's come with the elbow included. Maybe it is just missing from the box?
Old 03-08-2015, 05:50 PM   #17
escottcarp's Avatar
Mine is a 2002.
Here is the bag. Maybe, this item came from an older manufacturing lot before they included the elbow.
Name:	ImageUploadedByMustang Evolution1425858505.378853.jpg
ID:	176982Click image for larger version
Name:	ImageUploadedByMustang Evolution1425858523.533706.jpg
Old 03-08-2015, 06:25 PM   #18
Does that piece rattle when you shake it? The passenger side rattles, the driver side is just a straight through piece.
---------- Post added at 07:25 PM ---------- Previous post was at 07:24 PM ----------
But ev257 sounds familiar like the right part
Old 03-08-2015, 06:43 PM   #19
escottcarp's Avatar
Yes. It rattles.
It actually rattles better after soaking it in hot water for about 15 minutes.
Need a new steeda cai elbow!! Mustang32Bill 2011-2014 Mustang GT 8 05-15-2013 10:30 AM
6061 elbow Bret21 1996-2004 Mustang GT 9 09-22-2012 11:21 PM
Port Elbow & Throttle Body SNK3BTE04 SVT Mustang 0 04-04-2012 07:18 AM
PCV OR NO PCV ?????????? rick978 1979-1995 Mustang GT 13 02-24-2012 11:42 AM
where pcv valve on my 3.8L v6 valve cover to where? Pascullon Pre-2005 V6 Mustang 2 02-28-2011 08:47 AM
06:28 AM
