Headlight Problem! - Mustang Evolution
Old 03-07-2015, 12:04 PM   #1
TruBluStang03's Avatar
Headlight Problem!
How can I fix this, looks foggy and looks like there's water in there? Click image for larger version
Name:	ImageUploadedByMustang Evolution1425754988.870632.jpg
ID:	176902Click image for larger version
Name:	ImageUploadedByMustang Evolution1425755005.910818.jpg
TruBluStang03 is offline   Reply With Quote
Old 03-07-2015, 08:51 PM   #2
Speed_Mister's Avatar
Region: Arkansas
Rubber boot cover on the back side has a crack or is letting water get in some how.
2004 Mustang GT 5 Speed Full Bolt On 370rwhp 440rwtq
Full Bolt Ons
370rwhp 470rwtq
12.1 @ 117.9 (1.7) in 1/4th
7.6 @ 92.1 (1.6) in 1/8th
Old 03-07-2015, 09:59 PM   #3
Slater2111's Avatar
To clean the haze off of it believe it or not take some off deep woods bug spray and spray it on a cloth and wipe it on there really well. Then wipe dry. And you're done.
Sent from the mothership.
Slater2111 is offline   Reply With Quote
Old 03-08-2015, 08:06 AM   #4
2011 Kona Blue's Avatar
Originally Posted by TruBluStang03 View Post
How can I fix this, looks foggy and looks like there's water in there? Attachment 176902Attachment 176903
Sir, I had the exact same issue with my wife's van headlight. The problem, seal went bad and let's moisture in. I fixed that issue real easy. No more moisture like you have.
Solution was I took my cordless drill and drill bit and placed a small hole into the lower side of the headlight covering. No one can see it unless your looking for it. That way air can get in and dry out the moisture. Problem was fixed!
Old 03-13-2015, 12:12 PM   #5
fomoco4life's Avatar
That's what mine looked like when I got it. Chances are the moisture has damaged the inside of the lenses (unremoveable hazing, at least in my case). The seals on our lights suck. Easiest fix is to replace them and be sure to seal the new ones before install, they're not that expensive, and will be noticeable immediately and last for years.
Old 03-13-2015, 06:17 PM   #6
Let them dry out, pull them and lay silicone over all the seal areas. Worst case you can always bake them open and do a full restore on them and seal them back up and then silicone them and you'll be G2G.
Headlight Problem nhrider 1996-2004 Mustang GT 5 04-11-2013 04:21 AM
headlight problem D00m3dHitm4n 2011-2014 Mustang GT 7 01-06-2013 03:23 AM
Black headlight covers problem GTstang07 2005-2010 Mustang GT 22 01-11-2012 11:29 PM
Gauge and headlight problem MikeMaz7 1979-1995 Mustang GT 6 02-27-2011 03:56 PM
Headlight and directional problem mlbergeron 1979-1995 Mustang GT 4 03-31-2010 02:27 PM
03:44 AM
