Damn noise passenger rear - Mustang Evolution
Old 03-07-2015, 03:00 PM   #1
mustangt03's Avatar
I have a clunk or creek something in the passenger rear, has been doing it since i got the car. thought it was a spring. so i lowered the car no. figured its the shock got all new shocks NO. it sounds like its right in the trunk. where the shock bolts up i can push on that side of the car and it creeks. Push on the middle of the car nothing. any tips would be nice if you guys have had a problem like this.
mustangt03 is offline   Reply With Quote
Old 03-07-2015, 03:10 PM   #2
Carefully inspect your control arm bushings. Its difficult to tell if they are worn until you remove them from the vehicle.
You can try spraying them with some sort of lubricant and see if the noise diminishes or completely disappears.
If it does, you've found the source of the noise.
Old 03-07-2015, 03:12 PM   #3
mustangt03's Avatar
Never thought of doing that haha thanks, i'll give it a try.
Old 03-07-2015, 03:14 PM   #4
Billgluckman's Avatar
I have the same noise. All my bushings are new so I know that's not the cause for me
Billgluckman is offline   Reply With Quote
Old 03-07-2015, 03:25 PM   #5
On my car, I think that it is the worn out spring isolators that are making noise.
Old 03-07-2015, 03:38 PM   #6
mustangt03's Avatar
new isolators came with the springs so thats not it ..
Old 03-07-2015, 03:42 PM   #7
Yep. From your original post, the only thing thing left is the control arms.
Old 03-07-2015, 03:48 PM   #8
mustangt03's Avatar
I just sprayed the control arm bushings .. still there it sound more towards the trunk area.
Old 03-07-2015, 03:56 PM   #9
Are the shock mounts good and tight?
Old 03-07-2015, 04:26 PM   #10
mustangt03's Avatar
installed them with an impact wrench its tight, but it did it with the stock shocks too. I'm thinking it may be the top plate where the top of the spring meets? may need a few beed welds? But I didn't notice anything wrong when I installed it.. I'd hate to take it apart again ehhh. This noise is killin me slowly... for a year and a half.
Old 03-07-2015, 04:56 PM   #11
It can be frustrating tracking down these sort of noises.
It could still be a control arm bushing... That lubricant method of finding noises is not foolproof.
It seems a pretty sure thing that it is the rear suspension that is making the noise. There aren't really that many parts that move, so you will just have to focus the diagnosis on the parts that move up and down with the suspension.
Maybe put jack stands underneath the rear axle and have somebody bounce the car, while you are under it, listening for the source of the noise.
Old 03-07-2015, 05:27 PM   #12
mustangt03's Avatar
Yea, Im going to give that a try. I'm going to find it and once I do I'll post it on here so everyone that has this problem can get rid of it.
Old 03-09-2015, 11:56 AM   #13
SquatchMan's Avatar
I had a weird noise like this too in my car. Sounded like it was coming from the trunk, it was actually my passenger side headrest rattling and reverberating off my back glass. Weird.
40th Anniversary GT
04 GT
SquatchMan is offline   Reply With Quote
Old 03-09-2015, 11:59 AM   #14
What sort of control arms are on the car? Many aftermarket ones use junk poly bushings and will always make noise. If they are stock, its probably a shot rubber one. There are the ones on each end of the LCAs, on the chassis side of the UCA and on the SRA itself there are bushings where the UCAs attach.
Could also be a broken torque box. They are notoriously weak from the factory basically just being tack welded on. Perma fix is to drop the rear, sand down the paint on the seams, weld it up solid and then weld in "battle boxes".
Front passenger noise shawnpbigelow 1996-2004 Mustang GT 2 03-05-2013 09:41 AM
Noise passenger side top of motor mmike87 2011-2014 Mustang GT 0 10-31-2012 06:20 PM
Rear Passenger power window motor failure drnelsen 1996-2004 Mustang GT 5 06-26-2009 08:08 PM
damn it, damn it, damn it jimmy_beaner The Bar 15 07-01-2005 05:18 PM
"Damn cops" and "Damn women drivers" fast64 The Bar 10 11-27-2003 07:18 PM
10:42 AM
