Mid pipe installation - Mustang Evolution
Old 03-07-2015, 04:55 PM   #1
joe_117's Avatar
Name:	ImageUploadedByMustang Evolution1425772471.217862.jpg
So I lifted the car up to "try" and install the mid pipe. It's tougher than I thought. I don't know how you guys did it lol
joe_117 is offline   Reply With Quote
Old 03-07-2015, 05:18 PM   #2
Slater2111's Avatar
With a lift, 18 inches of extensions and a swivel socket. And plenty of PB blaster. Mine came out easier than the internets made it out to be. I have heard horror stories of people rounding off the nuts and then using a blow torch. Blah blah blah. Changing the tranny oil, and then breaking them loose and putting in my prochamber took about 2 and a half hours. And most of that time was waiting for the oil to stop dripping out of the drain and assembly of the prochamber to match up to my loudmouths.
Sent from the mothership.
Slater2111 is offline   Reply With Quote
Old 03-07-2015, 05:57 PM   #3
joe_117's Avatar
Was you changing your oil as well? Or...
Old 03-07-2015, 06:44 PM   #4
Slater2111's Avatar
I have a deep transmission pan on my tranny. It has a drain bolt for quick servicing. I changed half the oil in the tranny last Saturday. Couldn't get what was in the toque converter so I changed it again yesterday.
Old 03-09-2015, 07:58 PM   #5
Lorraine's driver
ab_mach1's Avatar
The hardest part for me was disconnecting the drivers side front O2 sensor. Took me like 20 minutes of painful concentration lol. It's so tight up in there.
I sprayed mine with PB blaster the night before and then again about 15 minutes before I started. It was tight, but came loose with a prob. I was most scared with the bolts connecting to the manifold. AM sells a passenger side manifold outlet gasket. I recommend getting one when you go to button up everything with the new midpipe. You can do it, just take your time.
And chock this rear wheels so she don't roll on you! Good luck.
IG: @azurebluemach
Instagram: @ab_mach1
Old 03-09-2015, 08:16 PM   #6
Slater2111's Avatar
Yea disconnecting the front O2 sensors are the worst part of the install. They're really up there and have to have skinny arms to get it. I was able to only get a thumb, ring and pinky finger on it to unplug it.
Old 03-10-2015, 09:32 AM   #7
The stupid hardware on the pass collector is a pain in the nuts too because of the angles and if you don't have 1/2" sockets than most 3/8 drive shallows are too short to get a good bite and the deepwells can't fit in the space... Like I said a 1/2" shallow socket solves this problem.
Definitely spray liberally with liquid wrench and let it sit for awhle and really seep in there. Heat helps too and propane torches are cheap.
H pipe vs x pipe vs straight pipe 509pony 2005-2010 Mustang GT 100 02-15-2015 08:35 AM
Mac H Pipe Installation Tips? V6 stang 1996-2004 Mustang GT 27 10-24-2014 01:15 PM
Mustang MagnaFlow Catback Exhaust Kit and X-Pipe Installation 99-04 Steve@CJPony 1996-2004 Mustang GT 3 09-09-2013 02:49 PM
Mid pipe with mid mufflers? Tompkins 2005-2010 Mustang GT 5 03-27-2010 12:26 PM
I want a new mid pipe 01mineralgrey6 1996-2004 Mustang GT 17 05-25-2005 09:16 PM
05:47 PM
