Do I need to clear my code? - Mustang Evolution
Old 03-09-2015, 09:56 PM   #1
Yellastang03's Avatar
So I had to replace bank2 o2 sensor because my previous one went bad and I have to take emissions but do I NEED to clear the code to get rid of my cel or will it go off by it's self once the computer recognizes the sensor is working properly? I don't want to clear it because a drive cycle takes me forever to complete which needs to be done before emssions. I replaced my o2 without unhooking the battery for this very reason.
Yellastang03 is offline   Reply With Quote
Old 03-09-2015, 10:09 PM   #2
oxford5pointoh's Avatar
It should clear itself after the CEL issue has proved to be fixed after 3 or so cycles. Drive the car 15-20 min. Turn off repeat. Should go off.
Old 03-10-2015, 08:25 AM   #3
fenixignition's Avatar
there was another thread in here somewhere about idle air control valves, and someone told us about a quick and easy way to recalibrate the ecu.
from what i remember, you disconnect the battery for at least 6 minutes, but some say 15 or so. then you let it idle until its warm, then turn on the ac for about 10 minutes i thinks, might have been only a few minutes, not positive. then there is a certain number of miles you wanna drive it, i think over 40mph. i dont think its any more than 10 miles. but i tried that out, and it reset everything, and idle'd and drove great. If i come across the thread ill try to remember to link it here.
2002 GT 5sp. 16x,xxx miles
Clear coat raised edge where vinyl decals were... need help saltysnaks Mustang Paint, Appearance & Detailing 22 11-12-2014 03:12 PM
FORD MUSTANG BRAINIACS what does r-code and/or c-code mean? kele74 Classic Mustangs 4 03-16-2010 05:12 PM
NEED ADVICE on 2006 Mustang GT Body and clear coat Lawman44 Mustang Audio & Video 8 06-19-2006 08:08 AM
Smoked or Clear Corners Stang01 The Bar 20 08-30-2003 07:41 PM
Where Can I get Clear Corners? 01 Stang Stang01 Mustang Audio & Video 16 07-30-2003 08:44 AM
07:44 AM
