99 GT 4.6L ProCharger Question - Mustang Evolution
Old 03-11-2015, 07:07 PM   #1
xfree143's Avatar
Do you use stock spark plugs with a ProCharger setup?
xfree143 is offline   Reply With Quote
Old 03-11-2015, 07:17 PM   #2
No
Old 03-11-2015, 07:25 PM   #3
xfree143's Avatar
I changed the plugs for the first time since I bought the car. Put in stock plugs but didn't drive it for a few days? Now when the boost kicks in at 5psi it runs like crap. Thru the old plugs away so I don't know what was in it.
Guess I will have to call ProCharger
Old 03-11-2015, 07:53 PM   #4
If you gapped them to stock spec then you are probably blowing out the spark, gap for a blower is much narrower. Call Procharger and see what they recommend or just use the google... she knows all.
Old 03-11-2015, 08:15 PM   #5
xfree143's Avatar
Yep stock gapped at 54 I think so what your saying makes sense. Now that you said that I think the gap on the plugs I took out was like 32-35 or so.
I will ask the all mighty Google but will also call ProCharger to check the plug number.
Old 03-11-2015, 08:42 PM   #6
The gap of the plug can also depend a bit on how much boost you are actually running.
Old 03-11-2015, 09:10 PM   #7
xfree143's Avatar
Before the plug change I was running 13 psi max, just did a Dyno run on it.
Old 03-12-2015, 05:23 AM   #8
WheelStander's Avatar
Dyno numbers?
Induction: Kenne Bell | wHp: 515 Tq: 503 | 1/4 Mile:11.09@123
WheelStander is offline   Reply With Quote
14 GT/Procharger Question slimguns 2011-2014 Mustang GT 0 12-12-2014 10:28 AM
Procharger question 2002VertGT 1996-2004 Mustang GT 23 06-09-2013 09:26 AM
Procharger question Darkhorse_MD 2005-2010 Mustang GT 5 01-03-2008 10:46 AM
Procharger??? Falcon Pre-2005 V6 Mustang 6 12-21-2003 10:33 PM
Procharger Squirrel Pre-2005 V6 Mustang 2 07-24-2003 08:17 PM
09:32 AM
