Inner two taillight bulbs don't work. - Mustang Evolution
Old 03-12-2015, 08:16 PM   #1
bullitt310's Avatar
I recently replaced the taillight bulbs on my '01 GT and the inner two (closest to license plate) are still not working. The reverse lights and outer bulbs work fine, but the inner two don't work at all. Any ideas?
Also, the lock/unlock and side view mirror switches don't work either. Are these related?
It's not a huge problem, but I just want everything in good working order. Any advice is appreciated.
bullitt310 is offline   Reply With Quote
Old 03-12-2015, 08:55 PM   #2
Mile high JDF's Avatar
Are you talking about the inner two not working when the brake pedal is applied?
As far as the lock/unlock you probably need a master switch but it's hard to diagnose things over the internet
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 03-12-2015, 09:20 PM   #3
bullitt310's Avatar
Yes, the inner two don't work when the break is applied nor when I use my signal.
It'd be nice if I could get the switches fixed, but I guess it isn't the end of the world for now.
Old 03-12-2015, 09:45 PM   #4
It's possible that you replaced the bulbs with ones that don't have a filament that lights up when the brakes are applied.
Look in the owners manual for the fuse descriptions and locations, and see if there is a fuse for the power door locks and power mirrors. They may be on the same circuit and it is simply a blown fuse causing them not to function.
Old 03-12-2015, 10:17 PM   #5
Two on each taillight or just the very inner ones, one on each light? If I remember right the very inner ones (one on each housing) do not light up when the brakes and signals are turned on, only when the headlights are turned on
Old 03-13-2015, 12:22 AM   #6
bullitt310's Avatar
Ha! Problem solved. Thank you.
Old 03-13-2015, 01:36 AM   #7
Glad that you got it fixed!
What was it?
Old 03-13-2015, 04:54 AM   #8
fenixignition's Avatar
which begs the question, why do they call for a double filament? or do they call for a single filament, and i just threw in a double just cuz i had them and they work? lol.
2002 GT 5sp. 16x,xxx miles
Old 03-13-2015, 12:05 PM   #9
bullitt310's Avatar
What was it?
Thanks- just as he said. I turned the headlights on and all was well. I had only tested it using the breaks and signals. Felt like a minor "duh" moment when I saw that they were working lol.
Old 03-13-2015, 09:14 PM   #10
ive done that. sat there and wondered, why they arent lighting up for my turn signal or brake light. thought something fried. then i saw another mustang and i was like "him too? wait.... ugh..."
Old 03-14-2015, 11:53 AM   #11
bullitt310's Avatar
Lol, little things like that can really be annoying, especially when you think it might be some complicated electrical issue. I bought my car new in '01 and never knew those bulbs only came on with the headlights. Then again, I just finally joined a mustang forum- what horrible decisions I've been making all these years
need help... inner, outer, or ball joint? imhooked 1996-2004 Mustang GT 0 06-06-2012 01:54 PM
Inner fender wells Quball19 1979-1995 Mustang GT 5 05-30-2012 04:17 PM
LED taillight bulbs? Blackedout Pre-2005 V6 Mustang 1 04-09-2012 07:44 PM
Inner edge of exhaust ...and all over the back of dailey 2011-2014 Mustang GT 4 03-09-2012 08:38 AM
Inner tie rod ends Justintriner 1996-2004 Mustang GT 2 12-10-2011 01:07 AM
06:22 AM
