Question - Mustang Evolution
Old 03-14-2015, 09:58 AM   #1
mustang_brody's Avatar
Question
Do anybody know why it's always oil sitting all around this ???????Click image for larger version
Name:	ImageUploadedByMustang Evolution1426348679.931161.jpg
mustang_brody is offline   Reply With Quote
Old 03-14-2015, 12:26 PM   #2
v8pony's Avatar
Bad pcv valve, cheap easy fix... I had the same problem, replace the pcv along with the hose, its cheap enough...I initially just changed my PCV valve and than upon closer inspection after I swapped it I noticed when giving throttle the line would collapse from being old and worn..save the time and just order both
02 GT
2013 Feb MOTM
2002 5spd GT
Feb 2013 Mustang of the Month
Old 03-14-2015, 12:28 PM   #3
v8pony's Avatar
http://www.latemodelrestoration.com/...And-Components
02 GT
2013 Feb MOTM
2002 5spd GT
Old 03-15-2015, 07:50 PM   #4
fenixignition's Avatar
Isnt that side (drivers) just a straight through piece? Last time I popped it off there was no rattling piece inside, just a straight thru hollow pipe. My passenger side has a rattling type pcv valve (functional). Does my car have the wrong piece? Do they have a pcv valve on both sides?
Sent from my GT-P3113 using Mustang Evolution mobile app
2002 GT 5sp. 16x,xxx miles
Old 04-13-2015, 11:18 AM   #5
Good question idk either
Old 04-18-2015, 07:50 PM   #6
escottcarp's Avatar
The PCV valve is on the passenger side. There is only a tube on the driver side.
My PCV valve was impossible to remove from the tube. It turned out the hose was split. So, check the hoses on both sides. You may have a split in that hose and oil drips on that area.
Smoke tires, Not drugs!!
escottcarp is offline   Reply With Quote
Question question!?!? AmericanBulldog Pre-2005 V6 Mustang 11 12-11-2013 08:24 PM
Wheel gap question and lca question Mdazi 2011-2014 Mustang GT 27 05-27-2013 07:11 PM
Wheel Question / possibly stupid question Rogue Slider Mustang Wheels & Tires 8 05-29-2012 12:21 PM
Question: I would like to know from you guys (See background and full question)? dumont75 General Mustang Discussion 16 03-03-2010 06:17 PM
Car question? Duh, of course it's a car question, silly!? imported_daman General Car Discussion 3 08-17-2009 06:40 PM
06:32 PM
