Next mod - Mustang Evolution
Old 03-15-2015, 01:47 AM   #1
joe_117's Avatar
Next mod
Exhaust is finally done. What should I do next? I'll worry about suspension when I'm out of school. But any suggestion?
joe_117 is offline   Reply With Quote
Old 03-15-2015, 07:10 AM   #2
Slater2111's Avatar
What do you currently have done to it
Sent from the mothership.
Slater2111 is offline   Reply With Quote
Old 03-15-2015, 08:15 AM   #3
joe_117's Avatar
Slp catback, bassani off road x pipe. That's about it😳
Lol sorry that's not much it's tough where I'm at, hard to get hours and play sports while doing high school!
Old 03-15-2015, 08:25 AM   #4
Dub9stang's Avatar
Never can go wrong with a CAI and a tune!
Brandon Reda
Dub9stang is offline   Reply With Quote
Old 03-15-2015, 08:38 AM   #5
joe_117's Avatar
Brandon Reda
questioning on that one! But I haven't researched any intakes or tunes closely. I know JLT is really good, but I've been told my car wouldn't run good because of JLTs diameter being so wide a lot of air would go through.
I was considering bama since they have free tunes for life and they got the new tuner. But I really want ortiz. I tried contacting them. It's really hard to.
Old 03-15-2015, 09:31 AM   #6
Slater2111's Avatar
I'd say a plenum and TB to take advantage of the new exhaust flow
Old 03-15-2015, 09:36 AM   #7
DetroitMuscle99's Avatar
Can't go wrong with any of the above listed mods. I would personally get a throttle body and intake plenum at this point. Also 3.73 gears or 4.10 gears would be a good idea. Since exhaust is going unrestricted now it's time for more air flow.
This is why we play the game... to separate the contenders from the pretenders!
DetroitMuscle99 is offline   Reply With Quote
Old 03-15-2015, 09:47 AM   #8
Gears and a DYNO tune.
Old 03-15-2015, 09:55 AM   #9
joe_117's Avatar
May do tb/plenum. Is it tough to take the stock one out? Also tricklflow/accufab good brands?
---------- Post added at 03:55 PM ---------- Previous post was at 03:54 PM ----------
Also how wide?
Old 03-15-2015, 11:00 AM   #10
Slater2111's Avatar
It's not hard at all to take apart. Just make sure you torque the bolts holding the plenum on the intake manifold. They are in inch pounds. It's a plastic manifold. If I could do mine over again I'd go 75mm. Summit racing sells a plenum/TB combo. It's made by trick flow and is very affordable. I'd get that if I wouldn't have got the C&L plenum.
Old 03-15-2015, 11:33 PM   #11
joe_117's Avatar
Actually...I may get the MGW shifter before I go on to performance mods. The shifter is terrible.
Old 03-16-2015, 06:30 AM   #12
Get the mgw. Then gears, trick flow plenum/tb and a MPT tune.
Old 03-16-2015, 06:59 AM   #13
joe_117's Avatar
Sounds like the order il do it in! Thanks! Later im going to replace coils, transmission flued, etc.. So that nothing major will happen
Old 03-16-2015, 09:38 AM   #14
Lorraine's driver
ab_mach1's Avatar
What do you have to keep the CEL off since getting your off road x pipe? I think I'd get a CAI/tuner combo of you find one for sale. Then you could get rid of the CEL (assuming it's on) along with breathing better. Having the tuner already, then you won't have to get one to correct your speedo when you condor the gears.
I waited later to do a short shifter on mine. I mean, it's not like your jamming gears everywhere you go, so it wasn't at the top of my list. In fact, I only bought mine as soon as o did because it was nearly $100 off because it was a cyber Monday sale lol.
Gears is always going to be the most bang for your buck. Constant enjoyment in every gear and at every intersection lol.
IG: @azurebluemach
Instagram: @ab_mach1
Old 03-16-2015, 10:56 AM   #15
CAI is a waste of money. Tuner will be able to turn off the CEL for an offroad pipe but won't be able to turn off any cops who decide to write you a fix it ticket so you might want to go catted if you live in a state with cops like that although it is actually a federal crime to remove them no matter what the state emissions laws are.
As far as the shifter, if you have a 00-down car you should have one simply as a longevity/durability item as the T5 and T45 did not come with internal stops like the 3650 and can mess up shift forks if you shift too hard with the stocker. As far as just having it... the stock shifter really does suck and having a nice aftermarket unit in there just makes driving overall more enjoyable. For gears just go 4.10s or even 4.30s and roll.
Old 03-16-2015, 11:36 AM   #16
joe_117's Avatar
I have mil eliminators. And my tranny is the 3650. I'm doing MGW shifter. Then plenum/tb!
Old 03-16-2015, 11:52 AM   #17
Someone has probably told you like 10 times on this forum (proably me lol) but make damn sure you do a good drain and fill on that 3650 if you haven't already with the factory corrected fill quantity.
Old 03-16-2015, 03:31 PM   #18
Panther140's Avatar
CAI wont do diddly squat besides make a cool induction noise.
Save your money for a real mod if you car about performance, get some gears if you wanna have more fun. Maybe a dyno tune if you want to squeeze the most power out of your exhaust improvements.
Exhaust actually matters and will affect power especially if you get it tuned.. Intake barely will do anything but make it sound cooler
Panther140 is offline   Reply With Quote
Old 03-16-2015, 04:19 PM   #19
joe_117's Avatar
What tranny fluid should I use? How much? I need to know EVERYTHING
Old 03-16-2015, 09:25 PM   #20
Pennzoil Synchromesh (yellow bottles at Autozone) and 3.2 quarts. Drain plug is on the bottom of the 3650, you fill by pulling the shifter and dumping in 3.2 quarts. Way easier than trying to fill from the side port. Also makes measuring really easy. Dump in 3 quarts and then fill one of the now empty bottles to right under 1/4 full and dump that in. Done.
Old 03-16-2015, 09:44 PM   #21
joe_117's Avatar
Should I drain this fluid asap?
Old 03-16-2015, 10:05 PM   #22
I would seeing as if it is the original 3.8 quart fill that is too much fluid and also, correct automotive practice is that when you buy a used car one of the first if not THE first things you do is to change every fluid in it.
Old 03-17-2015, 07:12 AM   #23
joe_117's Avatar
Hmm... I shall look into this. Thank you!
Old 03-17-2015, 07:18 AM   #24
5.0FordMustang's Avatar
For this model a throttle body spacer and a CAI would be sweet. I can say a tune would be the best investment being that your in HS and all. These model dont respond as well to tunes.
5.0FordMustang is offline   Reply With Quote
Old 03-17-2015, 09:18 AM   #25
joe_117's Avatar
I may do bama..
Old 03-17-2015, 09:46 AM   #26
Slater2111's Avatar
The TB spacers are a waste of money. Gears, TB and plenum, suspension and a tune will get you a long way.
Old 03-17-2015, 10:04 AM   #27
joe_117's Avatar
I may go 75mm on it..but I'm not sure...don't want to much air
Old 03-17-2015, 11:13 AM   #28
Slater2111's Avatar
I went 70. I wish I would have gone 75.
Old 03-17-2015, 12:13 PM   #29
TB spacer and CAI are a waste of money at this level. TB spacer is a waste of money pretty much period...
I may do bama..
Do MPT.
You forgot exhaust but agreed. And by exhaust I mean mid pipe/catback as the 96-04 stock manifolds flow just as well as a legit set of shorty headers. Its not like 95-down when the stock headers looked like they got chewed up and spit out and then put on the car.
75mm is the way to go, the PI intake does a real good job keeping the velocity up. TFS makes the best bang for the buck plenum/TB but I keep hearing the Summit Racing brand is a generic TFS set. Which would rock as its a lot cheaper.
Old 03-17-2015, 12:17 PM   #30
Panther140's Avatar
Gears will do SO much more for your car than a tune will..
Gears = night and day different power delivery
Tune = doesn't do ****, you have to pretend your car is actually faster (unless you have a heavily modded car, that is.)
Old 03-17-2015, 12:18 PM   #31
Slater2111's Avatar
Yea I forgot to include exhaust in that list.
Old 03-17-2015, 12:22 PM   #32
No... you can definitely tell from stock to when your tune is loaded, especially an auto.
Old 03-17-2015, 12:22 PM   #33
Slater2111's Avatar
Says the person who doesn't have a tuned car.
The tune was what I noticed the most...
Old 03-17-2015, 12:26 PM   #34
Panther140's Avatar
you wont get too much air from a throttle body. Its not like a carb where you have to have a certain amount of air velocity to keep the boosters primed. Your ECU is not gonna have a problem compensating for a tb
Old 03-17-2015, 02:24 PM   #35
I thought you said you were leaving this forum
Truck will be forsale next spring. What to get next? sonic04edge The Bar 28 09-26-2006 07:45 PM
Next least expensive Mod? 00vertstang Pre-2005 V6 Mustang 26 01-11-2005 04:41 PM
Next mod? blownsix The Bar 9 07-25-2004 06:13 PM
What should my next Mod be? tippie2000 Pre-2005 V6 Mustang 24 04-07-2004 03:49 PM
next mod: Rellik The Bar 11 10-18-2003 08:03 AM
10:34 AM
